Failed Emissions (High NOx) - Page 2 - JeepForum.com
post #16 of 21 Old 05-22-2010, 01:12 PM Thread Starter
twmart
I have a question about the plemun plate / gasket.. After reading some about the Plenum gasket... I checked the following things.
- Looked down the throttle body .. there is only a little oil more like damp.
- I checked the engine vaccum again 16. I removed the PCV and there was no vaccum when I covered the hole with my finger.
- removed the oil fill cap and no vaccum sounds.
also none of the about caused the vaccum to fluctuate it was steady at 16.
Thoughts................................
I am wondering if the PO removed the internals from the cat....
1989 Cherokee
1990 Cherokee
1999 Grand Cherokee
2001 Cherokee
twmart is offline
post #17 of 21 Old 05-22-2010, 01:22 PM
BigE3
NOx and what the cat is supposed to do is 2 different things
I like my Jeep, just like my women. 'Loose and Flexible'
BigE3 is offline
post #18 of 21 Old 05-22-2010, 02:15 PM Thread Starter
twmart
Maybe I will just do a tune up and oil change the get the free retest and see what the numbers are.. I am only over by .18 on the NOx...
I check one of the plugs Champion RC12YC had a tan color to it.... But the gap was at about .055
I was just thinking also wow OLD oil cause the NOx to read high??? I was thinking that if this Jeep only has 2k miles in the last 2 years then the oil in there is also 2 years oil...
1989 Cherokee
1990 Cherokee
1999 Grand Cherokee
2001 Cherokee
twmart is offline
post #19 of 21 Old 05-23-2010, 01:07 PM
Bossanova
catalytic converters: Reduction of nitrogen oxides to nitrogen and oxygen: 2NOx → xO2 + N2
Oxidation of carbon monoxide to carbon dioxide: 2CO + O2 → 2CO2
Oxidation of unburnt hydrocarbons (HC) to carbon dioxide and water: CxH2x+2 + [(3x+1)/2]O2 → xCO2 + (x+1)H2O
If your cat is not working your nox will be high. I just failed an aircare here in vancouver and changed the cat and went back through and passed.
you can check your cat to see if its working by using an infrared thermometer. bring the jeep to operating temperature and check the temp of the pipe going into the cat. then point the sensor right on the cat (not on the heat shield) the temp should be allot hotter. this means the cat is working because there is a chemical reaction happening in the cat and when its working it gets damn hot.
Bossanova is offline
post #20 of 21 Old 02-06-2013, 07:53 AM
5150Revren
This post really helped, thank you!
5150Revren is offline
post #21 of 21 Old 02-06-2013, 10:30 AM
MilanJeep
MilanJeep's Avatar
Put 3-5 gallons of E85 in before your next test, that will help a lot too.
98 5.9 ZJ - 4.5" lift, 33x12.50 MT/R Kevlars
02 Z06 - Supercharged, E85, lots of rwhp, built and tuned by me
Milan
MilanJeep is offline
97 ZJ Failed Emissions ***Please Help*** choyt80 ZJ Grand Cherokee Forum 36 06-24-2015 11:06 AM
95 zj 4.0 failed emissions! nobrand ZJ Grand Cherokee Forum 17 04-06-2010 09:40 PM
E22 Recall...did it now failed emissions oldskool ZJ Grand Cherokee Forum 10 06-12-2007 07:37 AM
Failed emissions advice please 94 greenmachine ZJ Grand Cherokee Forum 19 09-02-2006 12:44 AM
Failed Emissions! HELP! dpierson ZJ Grand Cherokee Forum 8 06-01-2005 12:37 PM
