Factory Track Bar Alignment Thoughts - JeepForum.com
post #1 of 6 Old 05-07-2012, 06:11 PM Thread Starter
GaryE30
I just installed a factory Moog track bar for my Jeep as she was showing signs of death wobble and the whole front end felt loose. I'm sure there is more that needs replacing up front (and rear).
Despite that, I am now having alignment issues. I jacked the truck up by the axle, removed the old track bar, installed the new one, and now my steering wheel is cocked about 15-20 degrees to one side when I'm tracking straight.
I didn't mess with any of the tie rods or any other steering components. Could there have been some built up tension/compression in the old track bar that the vehicle was aligned to and now that it was removed and a new one re-installed it offset the steering components a bit?
I will say that when the front end was up in the air I did grab the tire itself and turn it to allow room for my fork to pop out the ball joint. Then after that was removed, I went inside the cabin and turned the wheels straight before letting the Jeep back down on the ground.
I suppose I'll have to pick it back up and adjust it sometime. Just wanted some input to from the ZJ crowd.
Thanks,
Gary
GaryE30 is offline
post #2 of 6 Old 05-07-2012, 07:13 PM
dropped74
Did it fix your problems?
dropped74 is offline
post #3 of 6 Old 05-07-2012, 07:30 PM Thread Starter
GaryE30
There is less shimmying going on when I hit small bumps at speed. I haven't tested it out fully, but I can already tell it helped a bit. I know that the tie rods, control arms, etc are all worn out so they're all contributing to the slop.
It was getting pretty scary for a bit though. Little imperfections in the road made the entire front end feel like it was floating and attached to the chassis via spaghetti lol
GaryE30 is offline
post #4 of 6 Old 05-07-2012, 10:19 PM
KoreaZJ
1994 ZJ
Perhaps your old trackbar was bent.
I still had the original track bar when I was hit (not very hard) on the right front tire. After that, the steering wheel was off center, never knew why. The garage that replaced the bumper cover centered the wheel, likely by just adjusting the drag link.
All was good until my track bar bushing got badly worn and contributed to my first case of DW. Then when I installed a new OEM track bar, my wheel was off center AGAIN. It seems that my original TB was bent when I was hit, then compensated for by the garage adjusting the drag link. Then with a new "unbent" TB, I had to put the drag link back where it was originally and now everything is straight again.
KoreaZJ is offline
post #5 of 6 Old 05-07-2012, 10:32 PM
1skrewsloose
Same thing is going on with my 98 GC, death wobble gone, but steering wheel will shake at times so I know other parts are worn. Going to wait till all bad parts are replaced, then do alignment. Wish I had the cash to just go in with all new everything. Posted this same advice a while back, but didn't heed it myself.
1skrewsloose is offline
post #6 of 6 Old 05-08-2012, 05:45 AM Thread Starter
GaryE30
1skrewsloose - Yeah, I mean I understand that it is wise to replace suspension components all at once. I always do on my other cars, however, this jeep is my beater and it gets pieces and parts as they wear out.
KoreaZJ - It must have been bent or just really worn out when the car was aligned last causing enough shift in the axle to contribute to the degree the wheel is off. I'll just adjust the drag link until the wheel is centered.
Thanks,
Gary
GaryE30 is offline
alignment , track bar
Track track trackbar! 94ZJ-318 ZJ Grand Cherokee Forum 11 10-30-2010 08:01 PM
OME shocks vs. New factory shocks...my thoughts grebesjeep WK Grand Cherokee & XK Commander Forum 18 04-15-2010 04:14 PM
WJ Draglink and Track Bar Alignment Mjov23 ZJ Grand Cherokee Forum 4 03-25-2009 03:16 PM
alignment vs track bar Derek33 ZJ Grand Cherokee Forum 5 07-14-2007 08:29 AM
The quality of the factory amp when used without factory head unit senovia ZJ Grand Cherokee Forum 5 01-12-2005 08:24 PM
