Factory Stereo Woes - JeepForum.com
post #1 of 4 Old 06-08-2013, 02:09 PM Thread Starter
chalkboard
Factory Stereo Woes
My stock (not infinity) speakers on the passenger side have stopped working. They used to work as they should, but only intermittently for years. Now, when I have the balance to the full right, and put my ear up to them, I can just barely hear sound; balance all the way to the left, and I get nothing. Interestingly, when I move the balance to full right, the driver side speakers never reduce in volume, as I believe they should. The fader works as it should.
I have tried spraying cleaner into the potentiometer from the front, but no joy. I did this because these symptoms are similar to the way a vintage amp behaves when it needs cleaning. I was going to remove the unit and clean the potentiometer, but then read somewhere that the pots are sealed to cut down on interference. ?? I have inspected the wires in the door conduit boots as suggested elsewhere in this forum. The wires look fine, and besides I believe my problem is upstream of the passenger side speakers. After, I inspected them, I was unable to get the dang boot up snug, must be something I'm missing.
I don't have a wiring diagram, but I'm relatively sure, the wires are good on the passenger side in both doors, especially since they went out together.
Anyone have any ideas where I should look next? Are those pots really sealed? And what is the trick to get my conduit boot back snug?
Thanks!
2001 WJ 4.7/73k "Old Bones"
1997 ZJ 4.0/154k Sold
chalkboard is offline
post #2 of 4 Old 06-08-2013, 05:52 PM Thread Starter
chalkboard
Im a newb
As you can tell from my number of posts, I'm a newb. I should have put this in the Audio/Electrical category. Sorry
Hopefully, a mod will see this and move it.
post #3 of 4 Old 06-08-2013, 05:56 PM
Maine1994ZJ
Go here and select "Grand Cherokee ZJ" in the pull down tab for online manuals.
I use this a lot!
http://www.jeep4x4center.com/knowled...ex.htm#service
'93 V8 ZJ Mountain Goat Edition.
'95 V8 ZJ Limited, '97 4.0L ZJ TSi
'96 4.0L 2wd XJ, '88 4.2L YJ
Maine1994ZJ is offline
post #4 of 4 Old 06-09-2013, 10:35 AM Thread Starter
chalkboard
I use this a lot!
thanks for the info!
