-   -   Factory Stereo Woes (http://www.jeepforum.com/forum/f13/factory-stereo-woes-1533893/)
chalkboard 06-08-2013 02:09 PM
Factory Stereo Woes
My stock (not infinity) speakers on the passenger side have stopped working. They used to work as they should, but only intermittently for years. Now, when I have the balance to the full right, and put my ear up to them, I can just barely hear sound; balance all the way to the left, and I get nothing. Interestingly, when I move the balance to full right, the driver side speakers never reduce in volume, as I believe they should. The fader works as it should.
I have tried spraying cleaner into the potentiometer from the front, but no joy. I did this because these symptoms are similar to the way a vintage amp behaves when it needs cleaning. I was going to remove the unit and clean the potentiometer, but then read somewhere that the pots are sealed to cut down on interference. ?? I have inspected the wires in the door conduit boots as suggested elsewhere in this forum. The wires look fine, and besides I believe my problem is upstream of the passenger side speakers. After, I inspected them, I was unable to get the dang boot up snug, must be something I'm missing.
I don't have a wiring diagram, but I'm relatively sure, the wires are good on the passenger side in both doors, especially since they went out together.
Anyone have any ideas where I should look next? Are those pots really sealed? And what is the trick to get my conduit boot back snug?
Thanks!
chalkboard 06-08-2013 05:52 PM
Im a newb
As you can tell from my number of posts, I'm a newb. I should have put this in the Audio/Electrical category. Sorry :facepalm:
Hopefully, a mod will see this and move it.
Maine1994ZJ 06-08-2013 05:56 PM
Go here and select "Grand Cherokee ZJ" in the pull down tab for online manuals.
I use this a lot!
http://www.jeep4x4center.com/knowled...ex.htm#service
chalkboard 06-09-2013 10:35 AM
I use this a lot!
thanks for the info!
The time now is 07:08 PM.
