Factory security on 93 GC - JeepForum.com
post #1 of 5 Old 07-15-2002, 02:50 PM Thread Starter
Jackylman
Does anybody know a way to disable the factory alarm on the 93 Grand Cherokee. Its become a pain to deal with?
Jackylman is offline
post #2 of 5 Old 07-16-2002, 12:00 PM
bocephus
I've had problems with my system too...dealership said they couldnt deactivate it, and I didnt want to pay to have them figure out why it was glitchy...my solution is to always make sure, when leaving the car, to lock all the doors using the power switch inside, then, after all the doors are closed, I unlock the driver's door with the key, and then relock it with the key. You'll see the little "security" light on the dashboard display go off...I read in the manual that the security will arm only when all the doors are locked at the same time. I know this isnt the best solution, but I hope it helps you avoid draining your battery from constant alarms.
bocephus is offline
post #3 of 5 Old 07-16-2002, 10:14 PM
Drafter75
That's the correct solution short of disarming it permanently. I've never trusted that damn alarm in mine and that's exactly how I lock it up.
Drafter75
Proud V8 ZJ/WJ owner of
1993-1998-1999-2002 model years.
Have you hugged your Jeep today?
Drafter75 is offline
post #4 of 5 Old 07-17-2002, 01:01 PM Thread Starter
Jackylman
Basicly the way I've been doing it. Except for the locking the drivers door with the key. It will help to know there is a way to open the dam drivers door without the alarm going off.
Thanks for the info!!!!
post #5 of 5 Old 07-17-2002, 07:43 PM
Drafter75
As described above, this is the procedure I personally use...
When I park, and before I shut off the engine, I use the door lock button on the door to lock all the doors. Then I manually unlock my door by hand. Then I shut off my vehicle. When I exit the vehicle, I manually lock the door by hand and shut it.
This insures the alarm system doesn't arm itself... even by accident. You can verify this by checking your security light. It should be off. When re-entering the vehicle, you're safe to use the key in the door or the remote transmitter to unlock the door. This method should work just fine even if you have glitches in your factory alarm system.
I know it sounds like a pain in the butt... butt it works!
Drafter75
Factory security system is trippin the kill switch. tex62 ZJ Grand Cherokee Forum 0 07-30-2008 08:49 PM
5.9 Factory Security System sergiovilnius ZJ Grand Cherokee Forum 5 01-20-2008 04:55 PM
please help, ZJ factory security system problem! mudd ZJ Grand Cherokee Forum 10 06-20-2006 02:09 AM
factory security system??? XJ-NoDough ZJ Grand Cherokee Forum 0 12-16-2005 12:44 AM
disarm the factory security feature simonl01 ZJ Grand Cherokee Forum 1 03-18-2002 01:08 AM
