Factory Alarm Problem??? - JeepForum.com
post #1 of 5 Old 08-16-2009, 02:38 AM Thread Starter
CULate
1930 J-Series Truck
A 1998 Grand Cherokee Limited 5.9. Tonight out of the clear the factory alarm went off. So we went outside & nothing around no issues found. So about an hour later it goes off again. It appears this is going off by itself without any reason. We thought maybe a cat or something. But we live in a real quite place our neighbors cat is inside at night.
Anyway anyone have a problem with an alarm going off by itself & if so what is the fix? Can it be disconnected?
Thanks in advance.
CULate is offline
post #2 of 5 Old 08-16-2009, 03:17 AM
sandman
common problem, not sure of a fix but a quick search will show you how to disable it.
1993 Jeep ZJ. 4.0
sandman is offline
post #3 of 5 Old 08-16-2009, 10:59 AM Thread Starter
CULate
1930 J-Series Truck
I found several topics but none for the 98 limited 5.9. There seem to be some conflict as to disarming different years. Where are the pins on the hood & rear hatch.
Thanks for you quick response. I went last night & disconnected the battery. This morning I checked all the doors, hood & hatch & hatch window to be sure they were closed tight. rehooked up the battery & set everything.
Is there a purple with a yellow tracer on the 98 Limited 5.9 or is it a different color? Is it in the door panel or kick panel? That was confusing in the different topics.
Again Thanks for you info & any further info available by anyone.
CULate is offline
post #4 of 5 Old 08-16-2009, 11:18 AM
Tiggerrrrr
I believe the alarm system is the same on all zj's. The purple/yellow wire runs behind the kick panel, throught the boot in the door jamb and into the door. the reason most people ground it behind the door panel is because there is more room to work and its easier to find that wire in the door. There are a LOT of wires behind the kick panels. From what I've read since I've owned my ZJ, the Problem with factory alarm seems to be associated mostly with the drivers door keylock.
'95 ZJ Limited 4.0
2.25" BB , 31 10.5 15 Treadwright MTG's on Black Rock steelies
Everything "pimpin' Gold" REMOVED!
Looking for a REAR tow hook and bracket!
Tiggerrrrr is offline
post #5 of 5 Old 08-16-2009, 02:54 PM Thread Starter
CULate
1930 J-Series Truck
Thanks for your info. Greatly appreciated. You state most of the problem is around the drivers door lock. Is there a fix? Replace, Clean, etc.? I don't have the remote fobs for this Jeep & not sure where the best place is to buy them. Would buying Remote Fobs fix this? WHERE IS THE BEST PLACE TO BUY REPLACEMENT REMOTE FOBS & HAVE THEM PROGRAMED?
CULate is offline
factory alarm arms but wont sound off the alarm sdowney717 ZJ Grand Cherokee Forum 4 04-18-2009 07:09 PM
Help - Re Factory Alarm chrisrhodes100 ZJ Grand Cherokee Forum 6 03-12-2009 05:46 AM
electrical problem / factory alarm PLEASE HELP! adgjqetuo ZJ Grand Cherokee Forum 4 12-05-2006 03:09 PM
Factory Alarm problem DrewZJ ZJ Grand Cherokee Forum 5 05-13-2006 08:48 PM
93 GC Factory alarm Problem artburg ZJ Grand Cherokee Forum 2 10-13-2005 02:45 PM
