Fabbed my new roof rack-- whatcha think? - JeepForum.com
post #1 of 38 Old 07-13-2013, 03:29 AM Thread Starter
ErikTheRad
Just finished the rack and field-tested it this week on a 4-day camp trip in the Sierras. It passed with flying colors. Built almost entirely of 1" square steel tube, the completed rack (without lights, spare, or jack) weighs right at 40 lbs. Its VERY heavy duty. I didn't want a cheep-o Chinese mail-order spot-welded flex-o-rack, so I built this. Plenty of room and more than strong enough for everything I carry-- a spare tire, jack, fishing poles, tackle box, rope, tow strap, etc. I came up with my own mounting system because I didn't like the idea of simply strapping it to the factory rack. My way eliminates the factory rack altogether and uses 6 of the mounting holes. The hole drilled in the mounting flange fits perfectly over the exposed roof bolt insert, which prevents the rack from moving. Its secured into the inserts with 6 bolts and lock washers and a scosh of red Locktite. The jack mounts to the side of the rack on 3/8" bolts welded to the side rail, spaced to line up with the holes in the jack shaft and secured with Ny-Lock nuts and washers ground flat on one edge. Its even padlocked for security. On the opposite side from the jack are two "L" brackets welded on for fishing poles, shovel, or whatever I might want to carry. The spare sits on an X-brace and is secured using a length of steel tube welded to the center of the brace. I welded a threaded end onto the tube that uses the factory spare tire cone and wingnut. Up front are four mounting tabs for off-road lights, I chose to use Harbor Freight lights at $22 for all 4. The floor of the cargo area is steel mesh, welded in every 2" all the way around the perimiter. This rack was built to carry a 31" tire but I could make one to suit any tire size.
To do again theres a few things I might do differently. The top rail should be round tube instead of square, much better for tying off rope or to use bungy cords or ratchet straps. Also, I'd make the spare tire hold-down rod much shorter so that the spare would be carried face-down. This would keep the wheel out of direct rooftop exposure to sunlight and would create another area inside the wheel itself to stow more cargo, perhaps a tool kit or a few spare engine parts. A small cargo net would hold it in. If I make more racks they will have these changes and perhaps a couple other small alterations as well.
Anyhow, lemme know what you think. I'd be happy to make one for a fellow Jeeper (for a nominal fee, of course.) Everything you see can be changed to suit any particular need.
ErikTheRad is offline
post #2 of 38 Old 07-13-2013, 03:31 AM Thread Starter
ErikTheRad
Crap, wheres the pics? Hang on, gotta figure this out.....
post #3 of 38 Old 07-13-2013, 03:34 AM Thread Starter
ErikTheRad
Dangit!!! Oh wait...... it worked. More to come...
post #4 of 38 Old 07-13-2013, 03:41 AM Thread Starter
ErikTheRad
More...
post #5 of 38 Old 07-13-2013, 03:42 AM Thread Starter
ErikTheRad
Tomorrow I will post pics of the rack mounted to the Jeep, I haven't uploaded them from my phone to my computer yet.
post #6 of 38 Old 07-13-2013, 05:00 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Pics or ban.
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #7 of 38 Old 07-13-2013, 05:57 AM
Badphish
Looks good they make plastic push in plugs sor the sqaure tube that I've saw at harware stores or online that would finish it off nice and may cut down on some wind noise. Here is one I built for my kj out of emt conduit
Badphish is offline
post #8 of 38 Old 07-13-2013, 06:03 AM
hondakilla98
That's a nice looking rack. It's very well thought out. Do you have a Sun roof? Any reason the expanded metal is under the tube instead of on top?
5.9 Limited, RE 4" lift, RE FTB, JK take offs w/ 255/75/17 BFG MT's, 1.25" wheel adapters, ARB Bumper, Superwinch LP10000, K&N intake, Flowmaster, custom JL & Focal stereo, 20% tint, KOR roof mount tire carrier, JCR sliders, cobra 75 wx st
hondakilla98 is offline
post #9 of 38 Old 07-13-2013, 07:23 AM
BLarkin
Looks great. Can't wait to see the pics of it installed. I've been wanting to build one for my jeep, but just haven't had time.
BLarkin is offline
post #10 of 38 Old 07-13-2013, 07:41 AM
AnotherRedZj
Very nice!
I like the changes you have in mind too. I don't think I'm the roof rack type.....but I would totally sport that.
AnotherRedZj is offline
post #11 of 38 Old 07-13-2013, 08:09 AM
dnuccio
Looks beefy as hell. Good job
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #12 of 38 Old 07-13-2013, 12:58 PM Thread Starter
ErikTheRad
Thats actually one of the changes I would make, welding the steel mesh over the support bars instead of underneath. My thinking was I'd want the cargo tray as deep as possible, so I welded the mesh to the bottom of the rack. Problem is, now the two support bars interfere with items I may wanna put up there, such as an ice chest. However, I got lucky with my rather large tacklebox--- it fits PERFECTLY between the bars and keeps it from sliding around. Don't even need a bungy.
post #13 of 38 Old 07-13-2013, 01:08 PM Thread Starter
ErikTheRad
More pics...
post #14 of 38 Old 07-13-2013, 01:10 PM Thread Starter
ErikTheRad
Yeah I know, my lights are posers at the moment.... was in hurry to get it up there for camping, haven't hooked em up yet. And yes, although there was absolutely zero noticable wind noise, I plan to install 1" plastic square plugs in the ends of the tubes. It'll look more finished and help keep water out.
post #15 of 38 Old 07-13-2013, 10:13 PM
KDStewart
I have those lights and I need a different way of mounting them than what I have. I want a roof rack eventually so this may be perfect haha
edit: saw the tabs you mounted them on while looking through the pics again. Nice work!
KDStewart is offline
