F->r swap? - JeepForum.com
post #1 of 15 Old 12-09-2013, 08:37 PM Thread Starter
jnowak
F->r swap?
Correct me if I am wrong? I have a 4.0 taking the front coils put them on rear and putting v8 coils on the front will yield 3 inches or so. What else is required as far as track bar, lower control, or away bar links? I really don't know was just throwing some things out I think would need changing
jnowak is offline
post #2 of 15 Old 12-09-2013, 08:42 PM
bumperthumper
Hmm... subbed
bumperthumper is offline
post #3 of 15 Old 12-09-2013, 08:44 PM
riot1987
Search it. Been covered a LOT
Build thread^^
riot1987 is offline
post #4 of 15 Old 12-09-2013, 08:46 PM
Photog2000
I think this lift only applies to the TJ Wrangler. I did this with mine. I use my 4.0 coils in the rear, and a set of front coils from a 98 5.9 ZJ in the front. I got about 3" but there is a lot of difference in the two bodies.
Photog2000 is offline
post #5 of 15 Old 12-09-2013, 09:03 PM
JasonStebbins
See below.
Poop
JasonStebbins is offline
post #6 of 15 Old 12-09-2013, 09:31 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Do not.....argh. bad info.
Check the flaws page for front to rear swap. New shocks will be needed. F150 springs ride like junk. New guys, help the newer guys. Search isn't always the answer.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #7 of 15 Old 12-09-2013, 09:51 PM
JasonStebbins
It's not in the FAQ, unless I missed it?
There are a huge pile of options for this kind of lift (in order of expected lift: XJ I6, XJ UpCountry, ZJ I6, ZJ I6 UpCountry, ZJ V8, ZJ V8 UpCountry.
I6 Cherokee coils netted about 2" and the handling was awful, as the springs were too soft.
I6 ZJ Non-UpCountry give a solid 3", maybe they're good for 3.25". Stock ride and handling, full uptravel in a crossup.
V8 ZJ Non-UpCountry gives about 4". Stock shocks are almost at max extension just sitting still. Don't run them long because the ride is quite rough when the Jeep was empty.
Guesses:
Expect the UpCountry springs to be, say, 1/2" higher than the non-UpCountry versions.
If you only want 2" or so, I bet an I6 XJ spring would get there, if not, then an I6 XJ UpCountry probably would.
Pics include all three options : I6, I6 ZJ, V8 coils (in that order):
Poop
post #8 of 15 Old 12-10-2013, 02:34 AM
ZJfamilyfun
Hunter
Well put. You can search all day but sometimes not find the answer. It gives the new guys the opportunity to share and spread the knowledge that they have gained from this forum and spread it to the newer guys!! Thanks!
ZJfamilyfun is offline
post #9 of 15 Old 12-10-2013, 05:46 AM Thread Starter
jnowak
Jason,
The middle picture I assume is a f to r swap kit with zj coils 3in lift?
jnowak is offline
post #10 of 15 Old 12-10-2013, 09:23 AM
PolkaPower
With 4.5 RE coils in the front and front V8 up country coils in the rear, I got 3.5 in the rear. I put a 1" puck on top to level it out. That's on a 95 5.2. I wouldn't recommend it though. It was pretty stiff in the back and bounced around. 33's made it a bit softer. I guess you could get even softer shocks in the rear but I wouldn't do that again
All you are saving money on are two rear coils. You still need all of the other things that go with a 3.5" or 4.5" kit. Two coils are hardly worth making your ZJ ride like a dump truck over.
PolkaPower is online now
post #11 of 15 Old 12-10-2013, 09:59 AM
Timo_90xj
Timo_90xj's Avatar
Stock I6 front coils are same coil rate than the stock V8 rear coils are. Placed in the rear they should not ride any stiffer/ harsher than the stock rears, unless you've got stiff shocks.
Have to keep in mind though, there were about ten different coil rates for the ZJ when it was produced, so you'd really have to know which coils to use for which application for proper lift height and ride quality.
***Under construction***
Timo_90xj is offline
post #12 of 15 Old 12-10-2013, 10:24 AM
JohnnyZJ
i've done I6 coils in the rear from ZJ. gave about 3" or so. i used ZJ v8 coils up front with a 2.5" spacer and it was ok. you need longer length shocks. i have a recipe for this super cheap lift but you gotta earn it you should adress track bars at this stage though. because the front will pull the axle to the drivers side and the rear to the passengers side, so it can feel a little weird over some bumps because the wheels no longer track straight. i would do a front track bar....... or just stay with a 2" BB. either way you can just fit a 31" tire so might as well
07' JKUR rollin on 35s
JohnnyZJ is offline
post #13 of 15 Old 12-10-2013, 11:01 AM
huntsducks70
3.5 RE springs in front, my V8 fronts in rear, rear ended up being about 2" higher than front, cut almost a full coil, now it sits well and the ride is not bad, but it is definitely stiffer than stock
i can post a pic if you would like
1998 Jeep Grand Cherokee Ltd
5.2L, 231 Swap, 3.5in RE Fr Coils, RE Shocks, Fr to Rr, Front HD Clayton T-Bar and Bracket, Custom Raised Rear TB Axle Mount w/Stock Bar, Cut and Rolled Front Fenders, 15x8 w/31x10.50
Last edited by huntsducks70; 12-10-2013 at 11:01 AM. Reason: corrected spelling error
huntsducks70 is offline
post #14 of 15 Old 12-10-2013, 11:22 AM Thread Starter
jnowak
"All you are saving money on are two rear coils. You still need all of the other things that go with a 3.5" or 4.5" kit. Two coils are hardly worth making your ZJ ride like a dump truck over."
That's the debate I was having is the extra inch worth the $300 or so extra
jnowak is offline
post #15 of 15 Old 12-10-2013, 01:59 PM
huntsducks70
my ride is far from dump truck like. it actually feels very similar to the front, it moves well through its travel (i put zip ties on the shock shafts to monitor this), now add my 3 kids, wife and full tank. the spring rate seems perfect because of the added leverage from the lift, not looking to change those out, no need.
i have lengthened shocks, clayton dbl shear up front and custom mount with stock bar out back
