Extra Lift for my RC shocks - JeepForum.com
post #1 of 11 Old 01-16-2012, 09:01 AM Thread Starter
jamz
Hey people..
Ive got the budget 1-3/4'' Rough Country shocks on my ZJ..
everything else is still standard and in good working order..
My question is what would be the cheapest way now to get an extra 1'' or 2 on top of what ive got..I think 3'' would be what im looking for so i can get some bigger tyres on
Obviously i dont want to compromise the ride too much so what do you suggest?
Would extra bushes on the springs be OK as ive got the RC shocks?
thanks
jamz is offline
post #2 of 11 Old 01-16-2012, 09:44 AM
badbird17x
badbird17x's Avatar
1994 ZJ
Spacers would be fine. You may want longer shocks after the bb to max out articulation, but for mostly street use it will work great for the $.
94 jz, bruiser, la, cage,5.3 ls, 36 swampers 98 jz, the mutt, 3.5 iro, 33 swampers, avalanche conversion, 02 north face avalanche blacked out work truck, 06 rhino R1 engine, 4x4, Leeroy's custom paint, 04 escalade wifes truck 22s, 03 duramax 18s, completely blacked out, efilive by nick, wicked wicked truck, 39 chop chevy rod, aluminum 5.3 ls, 08 apex, 310hp mcx turbo, holz 162, completely black, CCM built.
badbird17x is offline
post #3 of 11 Old 01-16-2012, 01:06 PM Thread Starter
jamz
Thanks..appreciate the reply..
Any you can recommend which would suffice for now?
jamz is offline
post #4 of 11 Old 01-16-2012, 01:48 PM
-Joe-
-Joe-'s Avatar
No one can answer that without the model # of the shocks or knowing their extended length.
Your shocks can only extend so far, if you add spacers then they could over extend.
Google the model of shock or grab a tape measure.
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
post #5 of 11 Old 01-16-2012, 02:19 PM
badbird17x
badbird17x's Avatar
1994 ZJ
I'm confused. Are you stock height, with just longer shocks? Is it already lifted 1.75 with longer shocks? What do you want to do? Is it for highway use, with a little off-trail duty? The best thing is to get it the height you want while not worrying about shocks. Once your there, see what you need for shocks. For mostly street use I would bet your shocks will be fine.
post #6 of 11 Old 01-16-2012, 03:33 PM Thread Starter
jamz
Well its got the budget lift kit from RC that was the shocks and (bushes?) as im guessing the shocks dont lift the chassis? and yes it is roughly 1.5'' higher than stock..so its there budget lift kit
Everything else is stock including the springs..
I was wondering could i change the bushes that i have already to give it a bit more lift or would i have to take the next step up, control arms, sway bar etc..
afaik they are the Hydro8000 shocks judging by the RC site
jamz is offline
post #7 of 11 Old 01-16-2012, 03:36 PM
badbird17x
badbird17x's Avatar
1994 ZJ
Just replace your spacers with 3 in ones.
post #8 of 11 Old 01-16-2012, 03:53 PM Thread Starter
jamz
I will be doing some novice off-roading with it but i just the look of the higher rides hence my N00b questions...sry about that
As stated above would I need to make sure these shocks could handle the extra 1.5'' lift with a 3'' spacer or Do you think they would be Ok..
Im guessing its really a case of the higher you go the more you really need to change to better the off road capabilities?
So from mainly being a Road vehicle but as i said il be attending some Novice off road sites the setup i have with extra spaces will do OR am i knocking on the door of being a tight *** with the ? and i should really go for a proper 3'' lift kit?
again thks for the help
jamz is offline
post #9 of 11 Old 01-16-2012, 03:59 PM
badbird17x
badbird17x's Avatar
1994 ZJ
I love my 3 in bb. For what your doing you should be fine. Once the lift is in check your articulation and see if you need different shocks, with stock springs, and running a sway bar, I would bet you'll be just fine.
post #10 of 11 Old 01-16-2012, 04:33 PM Thread Starter
jamz
Thanks Badbird..
Am I better of sticking to the same brand as in RC for the extra 1.5'' or do you recommend some different?
So were hoping that everything else I have as in 'Stock' OE should be ok
jamz is offline
post #11 of 11 Old 01-16-2012, 05:06 PM
badbird17x
badbird17x's Avatar
1994 ZJ
Cheapest 3in spacers you can find. The rest should be fine.
Can i run 4 inch lift shocks..with 3 in lift coopdc78 ZJ Grand Cherokee Forum 5 03-14-2010 04:19 PM
any extra lift kits needs jeepjoker ZJ Grand Cherokee Forum 1 08-11-2009 03:19 AM
WJ: Cheapest shocks for 4" lift, What OEM Monroe shocks fit? iluvtruenos ZJ Grand Cherokee Forum 6 06-29-2009 02:05 AM
shocks for 4in lift JeepIJoe ZJ Grand Cherokee Forum 5 03-10-2009 01:53 AM
Gabriel Extra Heavy Duty Shocks ajmorell ZJ Grand Cherokee Forum 4 03-25-2008 10:48 PM
