extensive unibody frame rail rot!!!! - JeepForum.com
post #1 of 24 Old 11-02-2011, 09:50 AM Thread Starter
tower93zj
I am posting some pics of my 93 zj 4.0L which is about to get a long arm treatment that has extensive frame rail rot right where before the lower rear controle arm mounts. since this kit requiers me to cut these mounts off in doing so it will allow me to have easyer acsess to the frame rail for patching purposes. any help would be gereatly appreciated i am a diy kinda guy and am looking to make the repair myself.
http://i1083.photobucket.com/albums/...r/IMAG0003.jpg
http://i1083.photobucket.com/albums/...r/IMAG0002.jpg
http://i1083.photobucket.com/albums/...r/IMAG0004.jpg
tower93zj is offline
post #2 of 24 Old 11-02-2011, 10:05 AM
RED-85-Z51
To post pics I think you have to be a member for so many days or have a minumum amt of posts
RED-85-Z51 is offline
post #3 of 24 Old 11-02-2011, 10:12 AM
bubsydubsy
make a photobucket account, post the pics there, then copy and paste the links here... BAM pics have been posted haha.
heepin'
bubsydubsy is offline
post #4 of 24 Old 11-02-2011, 10:44 AM Thread Starter
tower93zj
post #5 of 24 Old 11-02-2011, 10:45 AM Thread Starter
tower93zj
post #6 of 24 Old 11-02-2011, 10:45 AM
bubsydubsy
damn dude, thats some rot..
heepin'
post #7 of 24 Old 11-02-2011, 10:50 AM Thread Starter
tower93zj
i know i need ideas its the only rot antwhere on the truck
post #8 of 24 Old 11-02-2011, 10:56 AM
MAUSS
That's nasty. Looks like it's been exposed to salt water. You could try welding in steel plate to reinforce it, but I'll bet you'll have to cut it way back to find solid metal. Rust is always worse than it looks.
'93 Limited (sold), '96 Laredo
MAUSS is offline
post #9 of 24 Old 11-02-2011, 11:07 AM
contraption22
If I saw that, I'd be looking in the paper for another ZJ.
contraption22 is offline
post #10 of 24 Old 11-02-2011, 11:10 AM
1stblack97ZJ
no click
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
1stblack97ZJ is offline
post #11 of 24 Old 11-02-2011, 11:17 AM
MONSooNmonkey
Start cutting until you get to clean steel.
Once you hit clean steel weld plate in there.
Unless you cut the rust away its going to rust again. Look in the paper for another jeep .
Sadface :(
MONSooNmonkey is offline
post #12 of 24 Old 11-02-2011, 11:31 AM
bubsydubsy
don't ditch it, keep it!
heepin'
post #13 of 24 Old 11-02-2011, 11:33 AM
theducksguts
Just fine another 4.0 ZJ without the rot and rust. They aren't expensive. Then swap all your stuff over and keep the other one for a parts vehicle.
Check out my
theducksguts is offline
post #14 of 24 Old 11-02-2011, 12:13 PM Thread Starter
tower93zj
Thanks for advise...but I think I'm gonna keep this jeep. I knew I had to cut out the rust I was wondering if the gage of steel used matters.... Like is going heavy gonna help or should try to match it to the stock
post #15 of 24 Old 11-02-2011, 12:57 PM
RED-85-Z51
GOing thicker than stock does nothing...going thinner is bad, same thickness makes welding alot less stressfull.
But my 89 SJ Grand Wagoneer had rust like that....I sold it for scrap. Once you get bad rot like that its hard to get rid of.
frame patch , frame repair , jeep build
Lowest steel line on frame rail, very rusty, brake line? ktmjeepguy ZJ Grand Cherokee Forum 12 10-08-2011 10:47 PM
cracked unibody frame lx2gt ZJ Grand Cherokee Forum 17 04-26-2011 08:07 AM
Another question about repairing my frame/unibody SpeedyMcready87 ZJ Grand Cherokee Forum 26 10-29-2010 02:41 PM
iron y hitting frame rail...help XrynoX ZJ Grand Cherokee Forum 39 10-26-2009 02:55 PM
Crossmember nut broken away from frame rail HighLonesome ZJ Grand Cherokee Forum 2 02-25-2008 12:46 PM
