Exstreme Exhaust Rattle (yes, Exstreme) - JeepForum.com
post #1 of 5 Old 07-19-2011, 01:42 AM Thread Starter
FlamingRain
The exhaust in my ZJ has always been a bit on the clunky side, but more recently, it's been more than noisy. It seems that at low revs at low gear, it seems to intermittently make this deep throated rattling noise that is extremely noisy as of recently, especially in 4lo 1st gear.
All I've got is speculation and having zero shop tools at my place, I can't exactly diagnose it w/o taking it to the shop (which costs extra $$$)
Is there any small little diagnosis tests that I can run on it w/o any shop tools to see if it's something loose, or is it really what I hope it isnt, a disintegrated cat? I've already done the standard listen to it while running under the car but I can't pinpoint where it's coming from.
2wd can really get you places you can't get out of without 4lo. - Ratmonkey
FlamingRain is offline
post #2 of 5 Old 07-19-2011, 01:53 AM
neatocj
1981 CJ5
Check everything, all bolts, hangars, heatsheilds and if its not one of those then hit/shake your muffler/cat and you might just find out if it is the exhaust.
Heat shield's can make quite the rattle...
Your not pushing the limits of your jeep until your on your side, then something breaks and it's time to go home.
'70 Camaro - Almost Done
'81 Cj-5 - SOLD
'06 MegaCab Cummins- Great White
neatocj is offline
post #3 of 5 Old 07-19-2011, 10:30 AM
LordHobbit
May be your motor and tranny mounts are shot.
93 red ZJ 190k 4.0. Spent more money than I should have ...
Isn't red the only color a vehicle should be?
If at first you don't succeed, use more speed.
LordHobbit is offline
post #4 of 5 Old 07-19-2011, 10:40 AM
zander21510
We had to get a new muffler because it was all rusted out.
zander21510 is offline
post #5 of 5 Old 07-19-2011, 05:07 PM
sabzz
Check cat. Thats what mine was. Sounded terrible at low rpms when idling or at a low gear/rpm. It was all the insides of the cat had been broken (common issue). I just took the cat out and welded in some exhaust pipe.
1998 ZJ 4.0 work in progress/DD
'97 ZJ 4.0|3.5 RC|31" -SOLD
sabzz is offline
08 CRD exhaust(?) rattle O111111O WK Grand Cherokee & XK Commander Forum 20 05-10-2014 08:56 PM
Odd Exhaust Rattle...96 ZJ TontoKowalski ZJ Grand Cherokee Forum 14 03-18-2010 01:41 PM
4.0 Exhaust Rattle ?'s The Donger ZJ Grand Cherokee Forum 4 09-06-2008 01:12 AM
exhaust rattle alivenkickin28 ZJ Grand Cherokee Forum 10 03-31-2007 11:10 PM
Did Jeep ever improve exhaust design on newer GC's? Found my Exhaust Rattle!!!! spankey ZJ Grand Cherokee Forum 0 10-15-2004 03:49 AM
