Exhaust sounds like a can of rocks? - JeepForum.com
post #1 of 4 Old 07-21-2009, 09:23 AM Thread Starter
YJDuff
I've noticed that when I put my jeep in drive and have the brake on the exhaust sounds like it is filled with rocks...Could that be from a bad muffler or converter? It barely makes the sound in park...I was also thinking if it was shaking enough to be hitting against something. Any feedback would be greatly appreciated. TIA
"Life is a garden, dig it!"
02' 4.0 WJ
2" bb lift
245/75/16 Goodyear MT/R
Rusty's Tow Hooks
YJDuff is offline
post #2 of 4 Old 07-21-2009, 09:26 AM
WiCkeDuDe
usually this comes from having a broken catalytic converter. The inside honeycomb material breaks and sounds like the rocks that you are describing.
WiCkeDuDe is offline
post #3 of 4 Old 07-21-2009, 09:31 AM Thread Starter
YJDuff
Thanks for your extremely fast reply! I will look at replacing it. I've received feedback from Kolak about exhaust upgrades. I guess now I'm forced to replace it. Thanks again!
02' 4.0 WJ
2" bb lift
Rusty's Tow Hooks
YJDuff is offline
post #4 of 4 Old 07-21-2009, 10:46 AM
Tweaks
You can tap, beat, or shake that converter just to make sure before you go replacing it. It should sound solid when you shake it. If you hear stuff rattling around then it's wore out and needs to go. You may even begin to notice poor flow issues or throttle response if it gets really bad.
I have a solid exhaust system but get a noise from mine. It turned out to be a worn bushing on the shift linkage to my transfer case. When the exhaust shakes it makes this bushing move around a bit.
Tweaks is offline
Driveshaft sounds like rocks rolling in a can... jeepers99 ZJ Grand Cherokee Forum 1 10-22-2009 07:35 PM
Jeep Hemi sounds like exhaust leak. ModularMayhem WK Grand Cherokee & XK Commander Forum 9 06-25-2008 07:06 PM
Exhaust Sounds 04Inferno ZJ Grand Cherokee Forum 8 02-26-2008 02:30 PM
SummitRacing Rocks! kdavis ZJ Grand Cherokee Forum 4 09-24-2007 02:52 PM
05 GC 5.7 exhaust - sounds funny JeepySteve ZJ Grand Cherokee Forum 5 09-01-2005 02:40 PM
