Exhaust manifold flange bolts or studs? - JeepForum.com
post #1 of 13 Old 04-19-2014, 01:09 AM Thread Starter
xcaliber81
Just wondering whats there studs or bolts sorry I never checked, real question is if there bolts i should probably replace them right? are they special bolts or will grade 8 bolts work?
xcaliber81 is online now
post #2 of 13 Old 04-19-2014, 06:22 AM
firsttimeZJ13
I went to autozone and bought exhaust bolts. Two of the old ones broke anyways. They come in a kit of 4.
1995 ZJ, 5.2L, NP249, stock suspension, e-fan, CAI, engine needs work!! Plan on lift and tires when money finds its way here...
firsttimeZJ13 is offline
post #3 of 13 Old 04-19-2014, 07:42 AM
AVR2
There are two studs (far left and far right of the manifold), the rest are bolts.
AVR2 is offline
post #4 of 13 Old 04-19-2014, 08:01 AM
OverlandZJ
Flange at the downpipe?
IIRC theres one stud and one through bolt.
OverlandZJ is offline
post #5 of 13 Old 04-19-2014, 08:40 AM
Uniblurb
Uniblurb's Avatar
Where the flange on the downpipe meets the outlet on the manifold they are showing 2 studs (J4007109) on the 94-96 ZJ parts list but they don't give thread size.
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 93 4.0 XJ (spare), 96 4.0 XJ (son's)
Uniblurb is offline
post #6 of 13 Old 04-19-2014, 10:00 AM Thread Starter
xcaliber81
Sorry yea where the downpipe meets the manifold. If they are studs are they replaceable?
post #7 of 13 Old 04-20-2014, 10:06 AM
Uniblurb
Uniblurb's Avatar
Would imagine you can since they sell the replacement studs. You'd probably have to put a whole lot of heat to the area around them to turn it red hot since they're designed like wheel studs as can be seen below.
http://www.ebay.com/itm/GENUINE-OEM-...-/261289895244
Another option is once you pound them out use the bolt/nut exhaust kit since you may have a more difficult time getting new studs installed.
Uniblurb is offline
post #8 of 13 Old 04-21-2014, 09:46 PM
RescueZJ
I just undid the flange on my 95 4.0. The studs were not going anywhere... bolts came right off with impact gun. I lost one nut while putting them back on and could not find correct replacement nut size outside of dealer..lucky for me I finally found the nut later that day.
RescueZJ is offline
post #9 of 13 Old 04-21-2014, 10:45 PM Thread Starter
xcaliber81
Alright thanks guys. After 492000 kms should I be worried about an impact snapping the studs? haha.
post #10 of 13 Old 05-03-2014, 12:43 PM Thread Starter
xcaliber81
So I thought i'd let everyone know mine were bolts, sounds pimp with just the front downpipe btw lol.
post #11 of 13 Old 05-05-2014, 01:18 PM
BLacher
@xcaliber81 Make sure to soak them in PB Blaster or Kroil or comparable (NOT while hot) at least the night before removing.
BLacher is offline
post #12 of 13 Old 05-05-2014, 10:52 PM Thread Starter
xcaliber81
sprayed them with lloyds movit 25 mins before and was able to loosen them with a ratchet.
post #13 of 13 Old 05-06-2014, 06:25 AM
BLacher
Excellent, I will have to check that stuff out. Never heard of it.
BLacher is offline
