Exhaust leak causes bad gas mileage ? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Exhaust leak causes bad gas mileage ?
Raceline/Allied Wheels on Sale NOW !Bds fox ipf 2.0 racing series shocks now available at rockSpartan Lockers FREE SHIPPING Excellent Prices
Unread 02-22-2007, 05:02 PM   #1
jeepunlimited
hey guys i read in another post on jeep forum that exhuast leaks could cause bad gas mileage with a 4.0L ? is this true, i know i have a cracked exhuast manifold...but i dont have the time nor the $$ to fix it right now ? soo if anyone can, can somebody explain how a exhuast leak would cuase bad gas mileage ??
1993 Jeep Grand Cherokee Limited
Green/Gold, Tan Leather
4.0L , 42RE transmission-- 242 selectable transfer case
Bone Stock with the acception of a K+N drop in filter and my aftermarket stereo, also did alot of new tune up wear and tear parts!
366 000 kilometers and stilll runs great :)
purchased for $125 bucks, amazing daily driver for the money
jeepunlimited is offline   Reply With Quote
Unread 02-22-2007, 05:10 PM   #2
Jeeples
With your vehicle being OBDI (Same basic motor as my YJ), you only have one O2 sensor, which is located before the catalytic converter.
Unfortunately for us with the 4.0, the manifold is most likely to crack where the collector meets, which means the exhaust gases can escape the system before passing by the O2 sensor.
Typically what will happen is the O2 sensor will get a false lean reading and tell the ECU to add more fuel to combustion chamber. This will result in worse gas mileage, and if bad enough can take out the O2 sensor and potentially clog up your catalytic convertor. Of course how long this takes depends on how bad your ECU is compensating for the lost exhaust gases and how long it has been that way.
Most people will recommend that you just use a stock manifold replacement, such as the one found on the upper left corner of this website. I recently changed mine out and went with an aftermarket design manufactured by PaceSetter. I was very happy with the fit and quality of the product I received, plus the price was right as well (compared to other aftermarket manifolds).
Good luck!
His: '96 ZJ, 5.2 Limited, stock, Maxxis Bighorns, '703 Injector Swap
Daily Driver: '05 SRT4, Stock turbo, 252 WHP, 321 FTLBS.
Hers: '03 WJ, 4.7 V8, Kolak Exhaust, IRO 3", JKS TB, KOR TB Bushings, 32" Cooper ATP's.
Jeeples is offline   Reply With Quote
Unread 02-22-2007, 05:11 PM   #3
ras2001wj
I would say exact opposite, exhaust leak relieves back pressure allowing for better flow and thus saving a few mpg's, i mean by all means correct me if i'm wrong...., but i would be careful with exhaust gasses leaking, dont poision yourself
Edit- ths post was being typed before the above was entered, and i didnt think of it that way.
[B]Rick[/B]
[SIZE="3"][B]2001 WJ Laredo 4.0[/B][/SIZE]
[SIZE="2"][B]2" BB
245/75R16 [/B][/SIZE]
[B]
[COLOR="Red"]Ron [/COLOR][COLOR="White"]Paul[/COLOR][COLOR="White"][/COLOR][/B][COLOR="Blue"] 2012[/COLOR]
"Freedoms Popular"
ras2001wj is offline   Reply With Quote
Unread 02-22-2007, 05:19 PM   #4
ajmorell
Yeah, another thing to consider is that your exhaust system requires a certain amount of backpressure to function correctly. Given, too much backpressure is a bad thing and will rob you of power but so will too little.
ajmorell is offline   Reply With Quote
Unread 02-22-2007, 05:37 PM   #5
Woody
Retired back to Bowties
Woody's Avatar
1985
I've run a vehicle with open headers, it ran like a bat and was loud as all get out. I then had to add mufflers (legal reasons) and for fun I timed my 0-60 and quarter times both with pipes and without. With pipes I was faster. Open headers will acutally decrease your torque as your valves require some backpressure to help them seat correctly. Without it, your engine may not run efficiently.
Racing engines are designed to be run with open exhausts so they put stronger valve springs in, plus they aren't meant to last 250K.
Removing your exhaust may sound cool, but check your times or dyno your rig and you will find that you actually loose.
Woody
1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch.
Woody is offline   Reply With Quote
Unread 02-22-2007, 05:50 PM   #6
ajmorell
Yeah......that's what I meant
Unread 02-22-2007, 07:06 PM   #7
micifus
Original GC'er
micifus's Avatar
you would have to change your valve clearances for it to run right and who the heck would want to deal with that
1993 Jeep Grand Cherokee Limited 4.0L I6
- OME Springs - 30"x9.5" Yokohamma's A/T-S -RE Shocks - JKS Quicker Disconnects - FM70 - E-Fan Conversion - 249->242 Swap -
1970 Jeepster Commando 225 V6
32"x11.5" BFG A/T
4" Lift
1987 Suzuki LT230S Quadsport
1996 Artic Cat ZR580 EFI
2005 Honda TRX450R
"For every one thing I fix two things break"
micifus is offline   Reply With Quote
Unread 02-22-2007, 07:50 PM   #8
greasefingers
1994 ZJ
The way I have been taught is: engines need no back pressure … per say. There is no back pressure on many engines (race vehicles, lawn mowers, etc)
But because of noise, emissions, and intoxication a long pipe is needed for the Cat, muffler, and to release the gases away from under the vehicle. This presents a dynamic flow issue. The engine emits exhaust flow in pulses (due to the nature of a very inefficient combustion engine). It is these pulses that create an issue as you want a smooth fast flow rate. If the lag time between each wave front of the exhaust is increased then the wave fronts catch up and collide; and then the flow rate is slowed down. Therefore it is critical for an exact pipe diameter to be selected. If a 4 inch exhaust pipe is use on any regular motor vehicle engine, then the flow rate will be decreased as the wave fronts will always be crashing into one another, with each exhaust stroke.
If you remove everything from the throttle plate forward (no intake plastic) and the entire exhaust system, then I believe one would have the maximum capacity of the engine.
Cheers Steve
Trained Professional Crack-pot
Go RU & WVU Football Teams
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
03 4Runner V8 (my wife's car)
94 Volvo 850 (my 16-yr old daughter's car) Five cylinder
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline   Reply With Quote
Unread 02-22-2007, 07:55 PM   #9
ajmorell
That's theoretically true, but that isn't how vehicles are designed. Like Woody said, some backpressure is necessary to make the valves seal correctly.
Unread 02-22-2007, 08:33 PM   #10
greasefingers
1994 ZJ
I am not sure that I believe that. If I was the engineer, then spring pressure should be correct for that.
Cheers Steve
Unread 02-22-2007, 08:41 PM   #11
ajmorell
No offense, and I don't want to get in a pissing match over it, but are you an engineer and did you design it? I'm not saying that I designed it but being a Mech. Eng. I have pretty decent idea of how things are designed and function.
Unread 02-22-2007, 08:43 PM   #12
Jeeples
As true as that may be, you also need and exhaust system to aide in scavaging of the combustion chamber (this is another affect from the engine pulses as well) and the extraction of heat.
You would need a lot of air flow around the motor itself to keep from burning up exhaust valves from excess heat in the engine bay or on the dyno stand.
Unread 02-22-2007, 08:45 PM   #13
greasefingers
1994 ZJ
No offense taken. I have a BSME but I am not an automotive engineer. I work with chemists.
Cheers Steve
Unread 02-22-2007, 08:53 PM   #14
ajmorell
Fair enough. Like I said not trying to get in a pissing match and I respect your opinion and thoughts, but I just think that they heads and valves were engineering to flow a certain way and that the rest of the system was taken into account.
Unread 02-22-2007, 09:30 PM   #15
rm2001wj
Let me see if I have this. Valve spring causes the valve to close. Back pressure tries to keep the valve open. Some how back pressure is needed to reduce the spring force so that the valve closes properly. Can someone explain how that works? Especially since back pressure can only be a few psi.
BTW, you don't have to post a copy your diploma before you answer.
2001 WJ Limited with Quadra-Drive, Kenne Bell Supercharger, 3-inch Kolak exhaust, Stillen rotors (F/R) and MM pads, Addco sway bars (F/R).
rm2001wj is offline   Reply With Quote
