Exhaust hangers - JeepForum.com
post #1 of 4 Old 05-07-2013, 01:22 PM Thread Starter
ZJMatt
Exhaust hangers
How do you guys with lifted ZJs that you wheel, hang your exhaust? From the factory I know they hang really low and would get torn off the second you hit a trail. I just re-did the exhaust on my new jeep and it's rubbing on the rear driveshaft when I make a right hand turn. Had this same problem when I did it on my old jeep too.
On the old jeep I was able to hang it from the rear sway bar and pull it away from the driveshaft, but that doesn't look like it'll work on the new one. I ended up hanging it from the little plate that hangs down from the floor. But I need to pull it further to the passenger's side. Also on either jeep I've never been able to get the tail pipe to sit straight...
The "Mall Crawler" - 1998 ZJ Grand Cherokee 5.2 V8, 5.5" LongArms, 32s, 12000lb winch & more.
ZJMatt is offline
post #2 of 4 Old 05-07-2013, 01:33 PM
riot1987
Ive had to modify and re-weld my Ypipe for my long arms, I have removed my tailpipe completely.
Build thread^^
riot1987 is offline
post #3 of 4 Old 05-07-2013, 01:57 PM Thread Starter
ZJMatt
My old jeep had 3" coil spacers and UC coils. New jeep has a 4.5" RC short-arm lift. So they're both around the same height on short arms.
ZJMatt is offline
post #4 of 4 Old 05-07-2013, 06:19 PM
blackjack12982
1994 ZJ
I'm somewhere in between 5.5-6", when I redid my exhaust, I put a new cat on an 18" glasspack and then a turndown. Mine dumps somewhere close to a foot before the gas tank, never had a problem with it getting caught on anything.
blackjack12982 is offline
