Exhaust flanges for easy removal--3" - JeepForum.com
post #1 of 6 Old 08-21-2009, 01:57 PM Thread Starter
ZJcrawler45
I almost have all of my parts in for my 3" exhaust set up. I have a 3 bolts flange coming off the headers which it'll bolt to and was wondering if anyone has ever put a flange on the tailpipe. I'm thinking about doing this b/c for accessibility - it will be easy to remove the whole section.
Also once the 2 piece 3" tail pipe is welded together is there any way to remove it in one piece?
Captain Nate
ZJcrawler45 is offline
post #2 of 6 Old 08-21-2009, 02:05 PM
gmp211
Use a couple of exhaust flanges to section the system up. Everyone told me to weld up my cat-back system. But since I know I will change components, it'd be stupid. Could be something like:
cat>flange>muffler>flange>tail piece
Just use exhaust gaskets and you wont have to worry about leaks.
2002 WJ - Forest Green
gmp211 is offline
post #3 of 6 Old 08-21-2009, 03:39 PM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
yes, disco the end of the trackbar and it snakes out
HighLonesome is offline
post #4 of 6 Old 08-21-2009, 11:08 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
I have flanges at the end of the y pipe. Between the cat and muffler, and between muffler and tailpipe. Makes work a ton easier on everything.
ratmonkey is offline
post #5 of 6 Old 08-23-2009, 07:35 PM Thread Starter
ZJcrawler45
Nice to know i'll be able to get the tail pipe out!
Ratmonkey - how exactly do you have the flanges bolted up/welded on? I was thinking of just flanging from the ypipe/cat and muffler/tailpipe but might be interested in your set up now. Can you post any pics? Thanks
Captain Nate
post #6 of 6 Old 08-24-2009, 01:44 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Just weld them to the ends of the pipe and clock them so there's a flat along the bottom. You can do one in front of the cat and one after the muffler and it'll be good enough for any work you want to do with it off.
Exhaust in way of oil pan removal!?!? klwong1 ZJ Grand Cherokee Forum 47 03-20-2013 03:15 PM
Problem with "easy entry/exit seat" makinitrain08 WK Grand Cherokee & XK Commander Forum 5 08-12-2011 11:33 AM
Easy one: Hub assembly removal UltimatE ZJ Grand Cherokee Forum 14 07-29-2011 08:35 PM
the never ending "easy" job (long but good) Irish_Assassin ZJ Grand Cherokee Forum 11 08-18-2010 02:23 AM
4.0 Exhaust Manifold Removal tpulliam79 ZJ Grand Cherokee Forum 16 11-10-2009 04:20 PM
