Exhaust bolt sheared by mechanic - Page 2 - JeepForum.com
post #16 of 22 Old 07-13-2014, 01:05 PM
zjosh93
Ouch. Those end studs see a good bit of force from the differential heating of the very long steel header flange. I broke that rear one tightening it the first time I had the header off. I was able to drill into it with a short drill bit on a 90 degree drill head and pull it out with a straight fluted screw extractor. I replaced both studs after that.
zjosh93 is offline
post #17 of 22 Old 07-15-2014, 10:14 AM
Professur
Originally Posted by Technohead View Post
Talk is cheap. Prove it. No pictures. No happen
Sure thing ... I'll run right out and find a ZJ so I can bust a manifold bolt off it because I feel such a great need to prove myself. Or maybe not. How about I just use google?
http://books.google.ca/books?id=2UbG...emoval&f=false
Or if that's too much reading ...
https://www.youtube.com/watch?v=IFSA0r6JpM8
Proof enough?
Professur is offline
post #18 of 22 Old 07-16-2014, 03:16 PM Thread Starter
pwoodbury1
Huh. Way cool. Cronaweld 333. Well, that was way beyond the capacity of these guys. Horizontal busted bolt too, not vertical. Thanks for the links....I'll remember this going forward.
pwoodbury1 is offline
post #19 of 22 Old 07-16-2014, 05:07 PM
jeepjeepster
My gosh!!! Almost $1000?!?! They broke the bolt?!
What did they do to get it out??
1994 ZJ-I6 w/216,000 mi
1998 ZJ 5.9 w/65,155 mi Slate Black
2004 KJ w/90,300 mi
jeepjeepster is offline
post #20 of 22 Old 07-16-2014, 06:21 PM
Professur
It can be done with common rods too. The 333 is just a particularly specialized rod for the technique. I run a brushful of anti-splatter gel into any threads exposed to serve the same purpose as the 333's fancy flux. Horizontal makes no difference with a quick freezing rod. The whole thing works because as the heat sinks down the restant it makes it expand. It wants to expand in all directions, but it can't because it's width is constrained by the walls, making all expansion go lengthwise. Then it cools and shrinks ... but it shrinks in all directions ... leaving a piece that's now slightly longer, and slightly skinnier than before. The added materiel and welded on nut are little more than a handle at this point. Run a thread chaser or tap down the hole to clean up any distortions and you're back in business. A practiced hand at it can clear the hole in under 10 minutes.
I will say, I've never attempted this on an aluminium head.
post #21 of 22 Old 07-16-2014, 06:50 PM
ozzy_2_me
1994 ZJ
personally, think pepboy's should have paid to have it extracted or bought you a new head.
ozzy_2_me is offline
post #22 of 22 Old 07-16-2014, 06:58 PM
KoolAidMan888
Aerospace CNC tube bending.
KoolAidMan888 is offline
