Ever have this problem - JeepForum.com
post #1 of 7 Old 05-10-2004, 06:51 PM Thread Starter
1st95gc
I have a 95zj, started it up this morning to go to work and the coolant level low was flashing in the jeep. About 3 and 1/2 hours later I checked it before going to lunch level was fine but the coolant bottle was very low, anyway during lunch no problem. Then leaving work about 8 hours later the coolant level low was flashing again. When I got home I started it up again after a couple of min. and it was fine. Is there a sensor going bad or do I just need to add coolant to the bottle? Anybody else have this happen? Thanks.
1st95gc is offline
post #2 of 7 Old 05-10-2004, 08:14 PM
Buddha_Kip
Buddha_Kip's Avatar
had this exact same problem in my 00' a few months ago. I also thought it was just a sensor or something, until I got underneath the thing. turns out the water pump was leaking on the gasket side. Lucky for me the truck is still under warranty. You may want to skootch under your truck to see if you are leaking any water.
2000 WJ Limited - 2.5" Rusty's springs WAAG 1-piece front brush guard custom built WAAG nerf bars PIAA 580 lighting Custom Paint One-off Aluminum Treadplate Door Entry Guards & Rear Bumper Step
1986.5 Porsche 928S - 18" Moda MD1 Autothority Chips Rear Muffler Bypass Short-Shift Kit
Grease Monkey & HNIC @ Clasik Auto
Buddha_Kip is offline
post #3 of 7 Old 05-10-2004, 10:12 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
When the engine is cold. Squeeze the top hose and see if there is fluid in it. You may just need to add fluid to the top fill mark and see how it goes from there.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #4 of 7 Old 05-11-2004, 10:59 AM
900Steve
don't forget to check the radiator cap. my girlfriend noticed i had some coolant leaking and i poped the hood, my cap somehow was loose. after closeing the cap and topping it off, i had the pesky coolant light go on and off after repeated startups, and eventually went away.
900Steve is offline
post #5 of 7 Old 05-11-2004, 08:27 PM Thread Starter
1st95gc
I put some coolant in the reserve bottle to the full mark and no more problem. What is weird is when I bought it the reserve was totally empty and the (low coolant level) never came on, oh well seems to be fine now,thanks for the input.
1st95gc is offline
post #6 of 7 Old 06-08-2004, 02:22 PM
acitydweller
i am going to have to try this because my low coolant level warning comes on as well... particularly when the car starts cold. once i arrive to where i go, shut the car off... then return to restart the car, the warning message appears to disappear. I'll go ahead and check/add some coolant and see how it goes.
Cheers.
acitydweller is offline
post #7 of 7 Old 06-08-2004, 04:29 PM
jiggajeeps
I have the same problem in mine. When I add coolant, it is fine for a couple of months, then the same problem again. A slow leak, right? If so, then where is it leaking? I never have puddles, even very small ones.
Current:
'98 TJ SE, stock
Past:
'04 KJ Sport, '98 5.9 Deep Slate, FIPK2, Mopar ECU, '93 XJ Country, '92 YJ 4.0 5speed
jiggajeeps is offline
is this a battery problem or alternator problem? Lady_Luck ZJ Grand Cherokee Forum 14 01-02-2009 08:04 AM
WJ Heated Seat problem and Mirror Problem JeepPleasure ZJ Grand Cherokee Forum 3 04-10-2008 02:00 AM
Problem with the wheel staus lights on dash and head light switch problem jeep2dmax ZJ Grand Cherokee Forum 0 12-21-2007 07:34 PM
HELP! SOS! 94 GC overdrive problem-Will VSS solve problem tinker1121 ZJ Grand Cherokee Forum 1 07-15-2005 09:08 AM
'93 Starting Problem,,, PCM Problem? jeff_connors ZJ Grand Cherokee Forum 0 01-19-2004 10:53 AM
