Evaporator Drain Tube? - JeepForum.com
post #1 of 4 Old 05-22-2005, 01:20 PM Thread Starter
-Joe-
-Joe-'s Avatar
Alright.. Seems alot of posts lately have been on the topic of AC.
Im trying to diagnose my problem with no cold air.
Was going to check the drain tube to see if it may be blocked with gunk. But I cant find it.
Seems it would be right on the firewall in the engine compartment.. But i just dont see it.
Can anyone help?
Its a 95 grand cherokee 4.0
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
post #2 of 4 Old 05-23-2005, 06:59 AM
Turbonut
You won't be able to see the drain tube. It is a straight plastic tube that is inside the frame assembly. That's why condensate will drip under the Jeep in the middle and in the front out of the frame.
This would not have any effect on the operation of the A/C. If no cold air, check if compressor is operating. Chances are refrigerant is low or gone from a leak.
Turbonut is offline
post #3 of 4 Old 05-23-2005, 10:54 AM
WhiteWater
When you first fire up the AC, does it blow cold air at all? If so, the the inside of the drain tube could be icing up and screwing up the heat transfer. it does this on my '98 and all I have to do is set it to vent for a few minutes. But if you're not getting cold air at all, then you're probably low on refrigerant.
WhiteWater is offline
post #4 of 4 Old 05-23-2005, 12:33 PM Thread Starter
-Joe-
-Joe-'s Avatar
It used to blow semi-cool air. So i got a gauge and it was low, so I recharged it.
It blew cool air when I had the cycling switch jumpered (Compressor would come on). But when I connect the wire back the compressor wont kick on.
Its not low as far as the gauge says. The recharge i used had a red dye in it, but i dont see it leaking anywhere.. visable or with a uv light.
Dont really have the money to pay a shop a ton of money to get it checked out.
- Joe -
-Joe- is offline
evaporator drain? carcrafter20 ZJ Grand Cherokee Forum 18 06-18-2015 08:52 PM
AC Evaporator drain tube location ZJ 5.9 ???? Franck ZJ Grand Cherokee Forum 2 10-16-2007 01:39 AM
94 Grand Cherokee evaporator housing drain? texasmail1962 ZJ Grand Cherokee Forum 1 06-14-2007 10:23 AM
ac evaporator drain rear floors wet again...95 Grand Cherokee foxtrot ZJ Grand Cherokee Forum 3 08-02-2005 06:45 PM
Evaporator Box Drain !!!! rinkside7 ZJ Grand Cherokee Forum 4 09-06-2004 02:08 PM
