European or USA headlights? - JeepForum.com
post #1 of 31 Old 05-20-2016, 02:34 AM Thread Starter
jofer
Hello jeepers,
I own an 1998 zj 5.9lx and I live in the Netherlands, Europe.
The zj's over here have electric height control for the headlights, so if you are heavy loaded of pulling an heavy trailer you can adjust the height of your headlights with an switch in the car.
But now I want to build smoked lights at the front, I already got the corner and bumper lights but some of the headlights that I see on eBay are different then mine.
I don't mind spending money but I want to buy the right product.
Could anyone tell me the difference between the European and USA headlights?
jofer is offline
post #2 of 31 Old 05-20-2016, 03:44 AM
Pierre_r
1989 XJ Cherokee
American lense are plastic and euro are glass.
You do know that it is illegal to have smoked headlights on public roads anywhere in europe right?
Its white or yellow at the front thats allowed..
Jeep Cherokee XJ 4.0 -89
Jeep Cherokee XJ 4.0 -90 (partsjeep)
Jeep Grand Cherokee 5.2 -93
Chevrolet Silverado 2500 6.5TD -94
Chevrolet C20 6.2 -82
Pierre_r is offline
post #3 of 31 Old 05-20-2016, 04:06 AM Thread Starter
jofer
Thank you for your reply
Is the connection at the back the same so I don't have a problem with installation?
I'm not going to use the original h4 bulb but bi-xenon morimoto and they are allowed.
The light is even better then the original h4 bulbs.
jofer is offline
post #4 of 31 Old 05-20-2016, 05:44 AM
jeepjeepster
I do believe the European lights use different clips on the back of the light. I imagine it has to do with the leveling system you were speaking of.
Its possible to use the US clips on european lights as Ive seen it done. You should be able to reuse your clips if you dont break them getting them off. Or possibly just buy new european clips and take the US clips out.
1994 ZJ-I6 w/216,000 mi
1998 ZJ 5.9 w/65,155 mi Slate Black
2004 KJ w/90,300 mi
jeepjeepster is offline
post #5 of 31 Old 05-20-2016, 07:13 AM Thread Starter
jofer
Ok, thanks all lot for your help.
Now I know what to buy
jofer is offline
post #6 of 31 Old 05-20-2016, 07:54 AM Thread Starter
jofer
I'm afraid the difference between the USA headlights and European headlights are bigger then I thought.
The back of the headlights on eBay are different then mine.
Maybe it's possible to change the glass?
jofer is offline
post #7 of 31 Old 05-20-2016, 12:17 PM
kg6mov
Hears the voices
kg6mov's Avatar
Yeah, the e-codes use a different bulb so the mounting and connector is different. The housings should be physically the same as the e-codes work in the US header panels fine.
kg6mov is offline
post #8 of 31 Old 05-20-2016, 12:28 PM
Timo_90xj
Timo_90xj's Avatar
Just buy the proper e-code headlights for the headlight-leveling version you have. As far as I know, the headlight leveling system is mandatory across all EU- countries after something like mid-90s if the vehicle came stock with the system.
The non-leveling headlights won't work anyways, mounting system is not the same. Headlight mounts are the same between e-codes and DOT headlights only if the EU- market ZJ does NOT have headlight leveling.
That being said, DOT sealed beam headlights are very crappy anyways, and the better DOT- lights with separate bulbs aren't that big of an improvement due to the not-so-good light pattern compared to e-codes - You want the e-codes
***Under construction***
Timo_90xj is offline
post #9 of 31 Old 05-20-2016, 12:34 PM
Buick350X
You do know that it is illegal to have smoked headlights on public roads .
ONLY if all you have are 2 head lights. There are no rules on where the headlights are located other then the front [ not on roof ] or how many. I have 6, by law only 2 must be clear white.
1995 Jeep Grand Cherokee Orvis 4.0L Up-Country + BB - facebook groups JeepOrvis.Club JeepZJ.Club
Buick350X is offline
post #10 of 31 Old 05-20-2016, 12:37 PM
kg6mov
Hears the voices
kg6mov's Avatar
The end of his sentence was "in europe". Are you saying that ohio is in europe? Or maybe that the netherlands are actually in Ohio?
In CA it is illegal to smoke factory headlights, thats the law, because the law is different in different places.
kg6mov is offline
post #11 of 31 Old 05-20-2016, 01:01 PM
jm8881
No rules?
Route: Ohio Administrative Code Ľ 4501 Department of Public Safety - Administration and Director Ľ Chapter 4501-15 Motor Vehicles-Lighting
4501-15-01 Headlights
(B) Height - Every headlamp upon every vehicle, including every motorcycle and motor-driven cycle, shall be located at a height measured from the center of the headlamp of not more than fifty-four inches nor less than twenty-four inches to be measured as set forth in section 4513.03 of the Revised Code.
jm8881 is offline
post #12 of 31 Old 05-20-2016, 03:31 PM Thread Starter
jofer
Honestly guys, i'm not worried about any DOT or EU signs.
The police won't give you a hard time here as long as your beam is good.
My problem is that I think the headlight won't fit.
Please have a look at the pictures and see the difference.
jofer is offline
post #13 of 31 Old 05-20-2016, 03:40 PM
Timo_90xj
Timo_90xj's Avatar
Look above what I posted - DOT or "normal" e-codes won't fit. You need the ones designed for headlight leveling system.
post #14 of 31 Old 05-20-2016, 03:52 PM Thread Starter
jofer
thanks, do think it's possible to swap the glass?
jofer is offline
post #15 of 31 Old 05-20-2016, 04:47 PM
Timo_90xj
Timo_90xj's Avatar
As far as I know, they should be about the same measurement between OEM- type headlight housings. If you go aftermarket.. well.. who knows.
