Estimated MPG on computer is weird... - JeepForum.com
post #1 of 5 Old 02-02-2013, 06:46 PM Thread Starter
Aureliametal
Put 20 bucks of fuel in it. The estimated MPG says around 100 miles. Drive it 50 miles and it says 10 miles til empty. Turn it off and restart it and it goes back up to 50. Drive a few miles and it goes down to 20 miles. Drive a few more miles and it goes down to 10. Then it slowly starts to climb over the next few miles until I shut it down again. The Jeep has a broken overdrive so I was wondering if that screws it up. Otherwise, this is very strange. Any idea's? Thanks
1998 Jeep Grand Cherokee 5.9 Limited 4X4 & 1998 Jeep Grand Cherokee 5.2 Limited 4X4
Aureliametal is offline
post #2 of 5 Old 02-02-2013, 06:49 PM
dnuccio
the overhead computer is not accurate at all. nothing is messing it up, thats just how they work. dont worry about it
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #3 of 5 Old 02-02-2013, 06:51 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
don't rely on that for anything. it takes the estimated amount of fuel left in the tank and multiplies it against the instant mpg you're getting.
ratmonkey is offline
post #4 of 5 Old 02-02-2013, 08:16 PM
newfieZJ
BTW , I recently went through a P0783 , and no OD . I tried different solenoids before finally replacing the trans(solenoids are in the trans I am using now) . After it was removed , I found out about the accumulator spring and it's issue with breaking and then no OD . Pulled the 5 screw cover and voila , 2 piece spring . I feel pretty confident I could have gotten OD with a new spring , 123 shifted great . I opted to switch because the oil had been let run really low , and some , well , a lot of debris in the pan when I opened it up . I didn't want to do the labor on the trans swap so I gave fixing it a shot , sure wish I would have tried the spring before swapping . I'd do a motor swap over the trans any day . After what I have experienced , I would certainly point the finger at a broken spring . Just thought I'd let you know . Could be a $10 fix , plus oil
Gas hand accuracy and DTE's aren't the greatest way to gauge what's left in the tank to take you that last 50 miles . I just filled up , drove 43 miles (70kms) since , and it's telling me 380 till empty (604kms). That's about 90-100 miles off what I will get , minimum . Never reset anything either . If I ran it down to using 21.5 gallons , that would make my 5.9 do 19.7mpgs . That would be better than the 14.2 I just pulled from the previous tank , same station used .
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #5 of 5 Old 02-03-2013, 01:13 AM Thread Starter
Aureliametal
Cool, I am going to get the cascade master kit and it comes with that spring. The MPG est. works perfect on all my other grands. Just cant figure why this one is different.
