Error Code P0201 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Error Code P0201
Bds fox ipf 2.0 racing series shocks now available at rock20 Ton Press Brake DIY Builder Kit @ Swag Off RoadRough Country Lift Kits and Parts!
Unread 04-06-2009, 02:35 AM   #1
jimmydots
Error Code P0201
Hi All,
I currently have a 12/2003 4.7 V8 Grand cherokee which is causing no end of problems. I currently have the error code P0201 coming up. the car is not buring fuel properly and is spiting out oil. I have not tried since problem occured, but i think it is currently undriveable.
About a year ago a couple of the cylinders burnt out and it went in for a costly repair and was driving fine. Then all of a sudden on startup (warm start up) engine light comes on and probs begin. emits coulds of thick smoke.
My question; does anyone have any detailed ideas as to what this could be and possibly what repair costs i could anticipate?
Your time and advice would be most appreciated. Thanks, James
jimmydots is offline   Reply With Quote
Unread 04-06-2009, 03:37 AM   #2
hillside250
I got P0201 and P0202 which are both fuel injector control circuit codes. My jeeps misses and does not run right but it doesn't smoke so I would like to know as well. I got a 2k WJ 4.7 4x4 auto with 100K on it
hillside250 is offline   Reply With Quote
Unread 04-06-2009, 01:05 PM   #3
HarleyDude
1992 XJ Cherokee
Error Code P0201
I have a 2K JGC 4.7 and just had a similar issue, no smoke but jerky when using cruise control, and threw codes P02XX also. I replaced the TPS, think it was $45 bucks at the Zone and problem fixed. O also clean the IAC while in there cuz the idle was doing the upsy downsy thing.
[I][SIZE="3"][B]1992 XJ (Daughters)
2000 WJ (Wifes)
2006 WK (Everyones)
Goal - All three fixed at the same time!
HarleyDude is offline   Reply With Quote
