Erratic oil pressure - Page 2 - JeepForum.com
post #16 of 19 Old 01-28-2014, 09:10 AM Thread Starter
JTWM0677
1994 ZJ
Originally Posted by herqulees
Well if I remember correctly there are two different sensors for oil pressure, one for the oil gauge, and one for the low oil pressure warning light. If the light isn't on and your gauge is just acting weird which is common along with the engine still sounds the same I'd say all is good.
Oil is due a change in about a week and a half, motor sounds he same as it always has.. Just cold natured like most jeeps I've read about..
Sent from my iPad Mini using JeepForum.. From who knows where this time..
JTWM0677 is offline
post #17 of 19 Old 01-28-2014, 09:19 AM
Purcell69
The oil change pending may have something to do with the lower pressure reading, but I would still bet on the sensor. In my old carbureted Chevrolets, I remember the oil psi would drop as I got closer to a change being due, though this was on a mechanical pressure gauge. Over time the oil would break down and become contaminated with fuel as well. Not so common on fuel injected engines unless there is a problem with the injectors.
-Joe
Purcell69 is offline
post #18 of 19 Old 01-28-2014, 02:04 PM
pageman
In the future maybe you should change the oil filter 1/2 way befor the oil is due just to help keep contaminents out of the unit. Its cheap and always worth a shot
pageman is offline
post #19 of 19 Old 01-28-2014, 02:31 PM Thread Starter
JTWM0677
1994 ZJ
This is the first oil change since I purchased it a couple weeks ago, but I'll keep that in mind in the future..
JTWM0677 is offline
