Engine Won't Turn Over - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Engine Won't Turn Over
JKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 09-07-2011, 12:58 PM   #1
1996Limited
1996 FSJ Cherokee
So I own a 1996 Grand Cherokee ZJ Limited (4L, V6) that I've recently taken off-roading for the first time. After climbing mud, rocks, and occasionally forging some standing water, she made the hour and a half drive home that night without incident. The next morning however, I can't get the engine to turn over. It starts up and just sputters back out. All the gauges are disengaged except for the fuel gauge which reads low/empty even though there is at least 3 gallons of gas in there. Why won't it start? Somebody help, please!
1996Limited is offline   Reply With Quote Quick reply to this message
Unread 09-07-2011, 01:07 PM   #2
dpshoup
2011 WK
You're gonna get spanked because ZJ's didn't come with a 4.0 V6...it's an I6. Did you check the battery? Try to jump it?
HT1 (SW/AW) USN RETIRED (HT-4946)
24 Jun 81-30 Jun 01
ASNT NDT Level III (VT, MT, PT)
[COLOR="DarkRed"]02 WJ-4.7 My DD[/COLOR] [04 WJ-4.0, 00 XJ-4.0 Gone]
[COLOR="SandyBrown"]03 WJ-4.0 Dau #1 DD[/COLOR]
93 ZJ-5.2 Dau #2 DD
[COLOR="Blue"]USN Jeep Club #153[/COLOR]
dpshoup is offline   Reply With Quote Quick reply to this message
Unread 09-07-2011, 01:38 PM   #3
sebian
If it stays running for 2-3 seconds before dieing, likely it is the security system kicking in. It could also be possible that you hydrolocked it running through the water.
1995 ZJ 5.2L V8 318. 230,000 miles and still rollin.
List of parts not replaced yet:
sebian is offline   Reply With Quote Quick reply to this message
Unread 09-07-2011, 01:39 PM   #4
speedbucket
kinda like his 96 FSJ cherokee? mythical creatures they are!
zjs aren't made for water. jump the battery and see what happens. if that doesn't work/ grab the blow dryer and start airing things out.
also, the factory alarm will engage if the battery was disconnected. use the key fob to disengage or turn your key in the door locks to disengage. are your lights flashing?
http://www.jeepforum.com/forum/f22/speedbuckets-zj-build-1361322/
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline   Reply With Quote Quick reply to this message
engine , grand cherokee , problems , start
