Engine Won't Turn Over - JeepForum.com
post #1 of 4 Old 09-07-2011, 12:58 PM Thread Starter
1996Limited
1996 FSJ Cherokee
So I own a 1996 Grand Cherokee ZJ Limited (4L, V6) that I've recently taken off-roading for the first time. After climbing mud, rocks, and occasionally forging some standing water, she made the hour and a half drive home that night without incident. The next morning however, I can't get the engine to turn over. It starts up and just sputters back out. All the gauges are disengaged except for the fuel gauge which reads low/empty even though there is at least 3 gallons of gas in there. Why won't it start? Somebody help, please!
1996Limited is offline
post #2 of 4 Old 09-07-2011, 01:07 PM
dpshoup
2011 WK
You're gonna get spanked because ZJ's didn't come with a 4.0 V6...it's an I6. Did you check the battery? Try to jump it?
HT1 (SW/AW) USN RETIRED (HT-4946)
24 Jun 81-30 Jun 01
ASNT NDT Level III (VT, MT, PT)
02 WJ-4.7 My DD [04 WJ-4.0, 00 XJ-4.0 Gone]
03 WJ-4.0 Dau #1 DD
93 ZJ-5.2 Dau #2 DD
USN Jeep Club #153
dpshoup is offline
post #3 of 4 Old 09-07-2011, 01:38 PM
sebian
If it stays running for 2-3 seconds before dieing, likely it is the security system kicking in. It could also be possible that you hydrolocked it running through the water.
1995 ZJ 5.2L V8 318. 230,000 miles and still rollin.
List of parts not replaced yet:
sebian is offline
post #4 of 4 Old 09-07-2011, 01:39 PM
speedbucket
kinda like his 96 FSJ cherokee? mythical creatures they are!
zjs aren't made for water. jump the battery and see what happens. if that doesn't work/ grab the blow dryer and start airing things out.
also, the factory alarm will engage if the battery was disconnected. use the key fob to disengage or turn your key in the door locks to disengage. are your lights flashing?
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
engine , grand cherokee , problems , start
After i turn my engine off i hear this clicking coming from the engine FST1994ZJ ZJ Grand Cherokee Forum 10 02-08-2010 12:31 AM
Is it bad to rev the engine and turn it off right away? OvenMits ZJ Grand Cherokee Forum 12 12-12-2009 08:46 PM
Engine is cranking but won't turn benks16 ZJ Grand Cherokee Forum 2 07-17-2008 01:01 PM
'99 4.0l, Turn Right, Engine Quits, Help ?! JIM ROLAND ZJ Grand Cherokee Forum 3 04-07-2007 09:11 PM
Jeep Doesn't Start (engine won't turn) Raben ZJ Grand Cherokee Forum 5 04-19-2005 08:38 AM
