engine swap question - JeepForum.com
post #1 of 5 Old 07-20-2009, 08:10 PM Thread Starter
jim75
I have a 98 zj w/ the 4.0. the motor is about smoked. I picked up a 93 w/ a 4.0 for cheep. pulled the motor out of the 93 ( runs great) and i am going to swap it into my 98. is there any problems i might run into?
any help would be great!!!!!! thanks!!!!!!!!!!
jim75 is offline
post #2 of 5 Old 07-21-2009, 12:25 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
You can pretty much only use the short block from the 94. You'll want to use everything else from the 98.
ratmonkey is offline
post #3 of 5 Old 07-21-2009, 12:32 AM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
As rat stated...you'd need to use just the bottom end (block/pistons).
All the top end (head, sensors, intake, injectors, all electronics) are different.
If you're gonna tear it that far down, may as well just rebuild yours....
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #4 of 5 Old 07-21-2009, 06:24 AM Thread Starter
jim75
i would but it is my DD and cant have it down but for a weekend. i do plan on having the short block (93) redone and maby bord out 30 or 40 over.
thanks
jim75 is offline
post #5 of 5 Old 07-21-2009, 01:12 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
thanks
getting it bored, you're into new pistons as well as rings. if it needs a clean up, do .005, you can make that gap up with rings, after .015 you need new pistons and you're getting into a $$$ rebuild.
Question About a 4.0 engine swap tdd8ball ZJ Grand Cherokee Forum 4 09-03-2009 12:23 PM
engine swap question sevierville01 ZJ Grand Cherokee Forum 1 01-31-2009 03:57 PM
Engine swap question joemadoo ZJ Grand Cherokee Forum 11 05-22-2008 06:35 AM
engine swap question vtlaxplaya16 ZJ Grand Cherokee Forum 2 10-02-2006 03:52 PM
New Engine swap question OffroadZJ ZJ Grand Cherokee Forum 4 05-16-2005 08:56 AM
