-   -   engine swap question (http://www.jeepforum.com/forum/f13/engine-swap-question-821012/)
jim75 07-20-2009 08:10 PM
:wave: I have a 98 zj w/ the 4.0. the motor is about smoked. I picked up a 93 w/ a 4.0 for cheep. pulled the motor out of the 93 ( runs great) and i am going to swap it into my 98. is there any problems i might run into?
any help would be great!!!!!! thanks!!!!!!!!!!
ratmonkey 07-21-2009 12:25 AM
You can pretty much only use the short block from the 94. You'll want to use everything else from the 98.
Kruzin 07-21-2009 12:32 AM
As rat stated...you'd need to use just the bottom end (block/pistons).
All the top end (head, sensors, intake, injectors, all electronics) are different.
If you're gonna tear it that far down, may as well just rebuild yours....
jim75 07-21-2009 06:24 AM
i would but it is my DD and cant have it down but for a weekend. i do plan on having the short block (93) redone and maby bord out 30 or 40 over.
thanks:cheers2:
ratmonkey 07-21-2009 01:12 PM
thanks:cheers2:
getting it bored, you're into new pistons as well as rings. if it needs a clean up, do .005, you can make that gap up with rings, after .015 you need new pistons and you're getting into a $$$ rebuild.
The time now is 10:14 PM.
