Engine stalling problem with 93 Laredo....please help - JeepForum.com
post #1 of 6 Old 06-22-2003, 01:47 PM Thread Starter
Silver1.8T
I have a 93 Grand Cherokee Lared0 with the six cylinder engine. Today, I went to start it and it will start up fine but the engine willstop right after that. It does not matter if you give it gas or not, it just kind of turns off. I have recently had all the spark plugs and the distributor replaced. What could this be? How can I fix it?
Silver1.8T is offline
post #2 of 6 Old 06-22-2003, 10:51 PM
68JEEP
Stalling
Try cleaning the throttle body. It might be carboned up not letting in enough air?
68JEEP is offline
post #3 of 6 Old 06-23-2003, 05:27 AM Thread Starter
Silver1.8T
I tried that but it did not work. Any other suggestions.
post #4 of 6 Old 06-23-2003, 07:12 AM
lambar
Does it just stall at startup, or has it stalled when on the road?
Are there any check engine, or check gauge lights on?
Do a quick looksee on the air filter, and also the spark plug wires. Maybe even examine the fuel filter (not sure if that will help).
I had a similiar problem a couple months ago. I cleaned TB, did an oil change, and used a fuel line cleaner twice. Problem hasn't reoccured.
They say the additives are worthless, but it couldnt hurt.
1996 GC Limited 5.2L
2" Coil Spacer
30" General Grabbers
lambar is offline
post #5 of 6 Old 06-30-2003, 02:16 PM
Hammerhead
Crankshaft sensor!!!
Hammerhead is offline
post #6 of 6 Old 06-30-2003, 07:14 PM
boing
It could be your factory alarm screwing up. Another guess?
Boing
boing is offline
93 ZJ Laredo: Tried everything; still idling low and stalling! SBrander11 ZJ Grand Cherokee Forum 4 02-11-2010 11:13 AM
97 JGC Laredo Stalling Problem PDMiller ZJ Grand Cherokee Forum 1 08-05-2008 08:38 PM
Intermittent Stalling Laredo '97 RonChennells ZJ Grand Cherokee Forum 0 01-15-2006 03:13 PM
1995 Grand Cherokee Laredo Missing and Stalling angelmom ZJ Grand Cherokee Forum 0 09-06-2004 06:04 PM
1996 GC Laredo Stalling Quitting angelmom ZJ Grand Cherokee Forum 5 09-30-2003 11:05 AM
