I don't know if ZJs have the same inline fuel filter set up like XJs do but I have heard people describe engine sputtering during hard turns before as a fuel filter problem. If you do have it, it is an easy change, if not I wonder if it might be a sign of early fuel pump failure. The second part is just purely speculation.
Check your plug wires for wear and tear...Had that problem on a Dodge Ram once. Look for wire shielding damage that could create a ground when turning...
thanks for al the help, i took the jeep out to the dunes with a full tank and didn't have any issues, probably a good idea to change the fuel filter as it has been awhile anyway, and i will take a look at the plugs.
mine does that when my tank is low. dont know if it is the filter or pump but i also noticed in my other zj that if i park on a hill with the pass side downhill with low gas it wont start, i think its just the placement of where the pick-up is. i even went and put gas in it that time thinking i ran out and with more or less 2 gallons in it it still wouldnt start. had to push it out of the parking spot with the rear end on the lower part of the hill.
hope this helps
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
