Engine Shudder / Transmission problem? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Engine Shudder / Transmission problem?
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 01-31-2011, 05:59 PM   #1
jczj318
So, my girlfriend's jeep (98 ZJ 4.0, 242 TC, 197,000 miles) has suddenly developed a large problem. It started when I was stopped at a light, and I started to feel some slight vibrations. Then, later on the same trip, while stopped again, the vibrations got worse. By the time I had it home, it was shuddering severely and felt like it was having trouble getting power. Once in the driveway, I put it through some tests.
Reverse has the worse shudder, which causes the engine to shudder, as well as the rest of the vehicle. It makes it seem like the engine is shaking.
In neutral, the shudder recedes to a quiter vibration.
In park, it is somewhere halfway in between reverse and neutral for severity.
I just checked the levels of all the fluids, and it was low on tranny fluid. I topped it off. It has been shifting hard into reverse for about half a year or so now.
Any help would be appreciated!
jczj318 is offline   Reply With Quote Quick reply to this message
engine , transmission
