Engine setting for 5 years, best way to prepare for start up? - JeepForum.com
post #1 of 66 Old 07-02-2012, 10:04 AM Thread Starter
hdrocknroll
It was running fine before was parked.
1: Whats the best way to prepare for start up?
2: Is it necessary to prim it, with a priming pump ?
3: Other tips on preparing it for start up?
Always !! Keep A Firm Grip On Your Tool !!
Watch Out For The Air Hose Gone Wild!! Or Wear A Cup,: True Story
Originally Posted by rooster51 View Post
Whats the worse that can happen? Your jeeps already broke.
hdrocknroll is offline
post #2 of 66 Old 07-02-2012, 10:06 AM
PolkaPower
Drain all the fluids and replace them with fresh would be the first thing I would do.
PolkaPower is offline
post #3 of 66 Old 07-02-2012, 10:17 AM
LordHobbit
pull the plugs and squirt just a bit of oil in the cylinders.
Charge the battery.
Pray the fuel pump still works ...
93 red ZJ 190k 4.0. Spent more money than I should have ...
Isn't red the only color a vehicle should be?
If at first you don't succeed, use more speed.
LordHobbit is offline
post #4 of 66 Old 07-02-2012, 10:27 AM Thread Starter
hdrocknroll
Charge the battery.
Have not done fuel press. check yet.
Turned it a little by balancer bolt, it isn't froze.
Cleaned elect connections hooked up power and barely bumped starter to check it.
Hooked up scan tool , key on, no codes.
Bat. fresh charged & 4 months old
post #5 of 66 Old 07-02-2012, 10:28 AM
Flyin
Charge the battery.
This & while the plugs are out, after it sets a while with oil in the cylinders, crank it over to get oil to the bearings & valvetrain. Replace plugs, check for fuel & spark. Start it up.
Flyin is offline
post #6 of 66 Old 07-02-2012, 11:29 AM
Canyon411
If the fueltank has held fuel for 5 years, you can bet it's varnished. Take the gas cap off and smell in the tank. There is no mistaking the smell of varnished fuel. Diluting won't help and you don't want to pump that sludge thru (a) the pump itself (b) the filter (c) the injectors. If the fuel is bad, you'll have to pull the tank and clean it out before putting fresh fuel in.
The rubber seals have probably gotten dry and brittle. I believe there are additives you can put into the fresh oil to help recondition the seals. Gaskets will be dry as well. I would watch closely for oil leaks when you do get her fired up.
Canyon411 is offline
post #7 of 66 Old 07-02-2012, 01:50 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Hey, take a video of that motor cranking.....
The fuel and oil are the main issues.
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
http://www.kevinsoffroad.com/
602.841.3355
For your performance needs:
kolak@kolakperformance.com
480.998.366
Texas ZJ1 is offline
post #8 of 66 Old 07-02-2012, 02:24 PM
MoparMan1990
1992 XJ Cherokee
Hunter
X1000000000 lol I wanna see that thing crank
MoparMan1990 is offline
post #9 of 66 Old 07-08-2012, 12:26 AM Thread Starter
hdrocknroll
I think I do need to pull the tank and clean it out.
With What Shall I Clean It, Dear People??
post #10 of 66 Old 07-08-2012, 01:11 AM
mr4x4
Blow out the fuel lines to some of that bad old fuel could have sat in the lines change fuel filter
94 stock zj and a 95 zj with a 5.5" lift with 35" bfg km2 a rear currie 9in with 4.56 gears an arb and 35spine axle shafts and 4.56 gears in the front Hp30 super30 kit arb 4.1 low range transfercase
mr4x4 is offline
post #11 of 66 Old 07-08-2012, 01:43 AM
Virmagicus
Virmagicus's Avatar
What motor?
Virmagicus is offline
post #12 of 66 Old 07-08-2012, 02:36 AM Thread Starter
hdrocknroll
Originally Posted by Virmagicus View Post
What motor?
5.7 Chevy Vortec
post #13 of 66 Old 07-08-2012, 03:18 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Not a mopar motor?
Ask a different forum.
are we talking about a ZJ here?
Hunter
04 4.7 HO, limited
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #14 of 66 Old 07-08-2012, 08:45 PM Thread Starter
hdrocknroll
Not a mopar motor?
Hunter
I did ask the same question on another forum.
I value everyone's input on here, and it's kind of a general question, no matter what engine it is.
I didn't think it was a big deal, to ask here.
No it isn't a ZJ, It is a Hoe, but the zj is the one doing the work, hauling all the parts home for the other repairs.
post #15 of 66 Old 07-08-2012, 09:47 PM
tcanthonyii
Put a battery in it. Add some fresh fuel and start it. If it runs then shut it off and do all the above. Never had an issue and done this to a ton of cars and trucks.
tcanthonyii is offline
engine priming , starting old engine
Jeep Limited been sitting for 6 Years!!! Where do I start! Jeepin2637 ZJ Grand Cherokee Forum 200 10-25-2013 08:54 PM
Setting here at the pizza place and no start hdrocknroll ZJ Grand Cherokee Forum 20 06-05-2012 05:16 PM
ZJ hasn't ran in years where to start WickedZJ ZJ Grand Cherokee Forum 8 09-22-2010 09:32 AM
Engine Block Replacement For a 1996 what years will work reeferman ZJ Grand Cherokee Forum 1 01-23-2010 12:19 AM
96 ZJ sitting for 3 years, start procedure defender ZJ Grand Cherokee Forum 16 01-13-2009 02:26 PM
