Engine rotates but no start - JeepForum.com
post #1 of 8 Old 05-02-2004, 10:10 PM Thread Starter
turk
'ello all. So my 98 ZJ 4.0 decided not to start again today after I returned from Dunkin Donuts. It started fine earlier and about 3 hours later I go to start her up and the engine rotates, but no start. I had this happen once before, last week. Though last week it started after 4 attempts. I have seen some posts of similar problems but did not see any conclusive causes (it is entirely possible I just overlooked it).
Any help would be greatly appreciated.
Thanks in avance,
Turk
It doesn't matter what you drive as long as it is a JEEP.
98 JGC Laredo 4.0, 3" lift, Rustys adjustable UCA's & LCA's, Custom K&N intake, high flow exhaust, Jet chip Stage 2 and 32x11.5 BFG TA's
turk is offline
post #2 of 8 Old 05-03-2004, 01:13 AM
RockPaws
RockPaws's Avatar
Hard to say, need more info...
Any fuel pressure? possible fuel pump problem.
Any spark? Ignition problem.
Check all electrical connections, make sure they are secure.
01' Jeep TJ (Jeep #5)
3.5 RE Custom SuperFlex, Raingler, Kilby, Currie, Banks, Borla, American Racing, Custom mods, Always more in the works.
RockPaws is offline
post #3 of 8 Old 05-03-2004, 01:20 AM
djorkboy
djorkboy's Avatar
I had the same problem, turned out to be a fuel delivery issue. At 95,000kms the fuel filter was the original factory fitted one, car had been dealer serviced for 6 years without them ever replacing the fuel filter (prestige dealer my a$$, I hope they take more care with the porsches and ferraris they sell), it ended up fouling the fuel pump and the landed-in-australia cost for a fuel pump was $1700!!!
djorkboy is offline
post #4 of 8 Old 05-03-2004, 09:58 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Check the ignition coil?
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #5 of 8 Old 05-03-2004, 10:13 AM
greasefingers
greasefingers's Avatar
1994 ZJ
Pull the coil wire off the distributor and hold it close to the block. If you have spark, then I would suspect the fuel pump, but I would not rule out the Cam & Crank sensors. Your problem is very difficult and annoying due to the issue being intermittent.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #6 of 8 Old 05-04-2004, 10:35 AM
cfkingfish
cfkingfish's Avatar
I dont know how common the crank position sensor going bad is on ZJs, but it tends to be one on XJs of most years. Try checking that out - basically get the codes read on it if you can.
-Christian
Christian
89 XJ 4.0 AW4
K&N 6x9 cone filter setup
Converted to TJ axles - 5-297 U-joints
Optima Red Top
Custom exhaust
www.ishopfaulkner.com
cfkingfish is offline
post #7 of 8 Old 05-10-2004, 08:56 AM Thread Starter
turk
Hey all thanks for the input. Due to time constraints I took it to a garage near my house and had it diagnosed (and fixed before I heard the diagnoses). It was a combination of a bad crank sensor and a bad pick up (pic-up). I wish I had more time to diagnose and repair it myself. I would have save at least $120.00 in labor charges and maybe a bit in parts cost. I guess if you do not have a garage and time to work on your vehicle you have to do what is necessary.
Anywho... Thanks again!
Turk
turk is offline
post #8 of 8 Old 05-11-2004, 01:08 PM
Zaphod
SACPOWERTV.com
Zaphod's Avatar
1981 J-Series Truck
For Fuel Pump replacement issues, check out the link in my sig. It's fooking brilliant. Much love, Swampy
*edit*
Damn, you have to be registered to view it now... that's bull
Ryan
81 J20 8400#
"The existence of flamethrowers is proof that someone,
somewhere, said to himself, "I want to set those people
over there on fire, but I don't feel like walking over there to do it."
Zaphod is offline
engine will not start nickp ZJ Grand Cherokee Forum 1 07-03-2008 12:02 AM
I can't start the engine Decatur ZJ Grand Cherokee Forum 5 10-13-2007 01:30 PM
Who rotates their full size spare tire? Test ZJ Grand Cherokee Forum 8 12-02-2005 11:41 PM
Longer than normal engine crank time prior to engine start tsb blizzboy283 ZJ Grand Cherokee Forum 7 10-15-2005 10:50 PM
4.0 engine start delay?? MoparPower ZJ Grand Cherokee Forum 1 10-15-2004 12:14 AM
