engine removal to get at head gasket - JeepForum.com
post #1 of 16 Old 07-30-2007, 09:07 AM Thread Starter
johnboy2007
Hi there,
I have a 1998 (4.0l) GC with a blown head gasket. In order to remove the head gasket do you have to remove the engine. It would appear the bulk head is preventing the removal of the rocker cover. Any ideas.
Many thanks
johnboy2007 is offline
post #2 of 16 Old 07-30-2007, 09:13 AM
ajmorell
ajmorell's Avatar
Uhh no way. The head is straight on top of the engine, why would you need to remove the entire engine? All you really need to do is disconnect everything from the head (throttle body, intake, exhaust, etc) and pull it off.
ajmorell is offline
post #3 of 16 Old 07-30-2007, 09:43 AM
BNB
changing the headgasket on a 4.0 is like changing a diaper...everything is disconnect, lift off, clean up put a new gasket on, and reconnect
2000 Jeep Grand Cherokee Laredo..daily beater
2006 Mazda 3..zoom zoom
1980 Corvette L82 Edition..The Blue *****
BNB is offline
post #4 of 16 Old 07-30-2007, 09:45 AM
ajmorell
ajmorell's Avatar
Yup, probably a good days worth of work if you haven't done it before. It takes ~2-3 hours to get the manifolds off and everything else disconnected for a first timer, probably an hour for a seasoned vet.
ajmorell is offline
post #5 of 16 Old 07-30-2007, 09:47 AM
BNB
an hour? damn boy you must be moving at snails pace...unless of course you are doing the normal method of..
Beer
wrench
beer
wrench
etc..
haha
BNB is offline
post #6 of 16 Old 07-30-2007, 09:53 AM
ajmorell
ajmorell's Avatar
Beer
wrench
beer
wrench
etc..
haha
I do like that method but I was speaking from experience. I have only had to tear that apart 1 time to do my exhaust manifold and it took me a good 4 1/2 hrs or so to get it done. Next time I could probably get it done in 3 hrs or so, but it's all part of the learning experience.
ajmorell is offline
post #7 of 16 Old 07-30-2007, 10:00 AM
BNB
gotta learn somewhere...and air tools help too
BNB is offline
post #8 of 16 Old 07-30-2007, 10:03 AM
Kornik
Not so newbie :-)
Kornik's Avatar
Better be careful with air tools around such things. Broken threads are very time consuming to fix :-(
92 XJ Laredo Mods: bored TB, 3" lift, 1-ton steering
93 ZJ Limited Mods: bored TB, K&N insert, e-fan; prothane bushings, NP242J, 3" lift, 1-ton steering; Atlas winch
Kornik is offline
post #9 of 16 Old 07-30-2007, 10:05 AM
ajmorell
ajmorell's Avatar
They do, but not really with replacing the head gasket since there really isn't anything you can use an impact on (the only thing I can see using is an air ratchet).
ajmorell is offline
post #10 of 16 Old 07-30-2007, 10:08 AM
BNB
i was talking in general...
BNB is offline
post #11 of 16 Old 07-30-2007, 10:13 AM
ajmorell
ajmorell's Avatar
I agree 100 times over, but we are killing this guy's thread so no more chit-chat.
ajmorell is offline
post #12 of 16 Old 07-30-2007, 10:16 AM
BNB
back to post at hand..
just got snag a Chiltons or Haynes manual..it explains in detail and pictures on how to do this..good luck!
BNB is offline
post #13 of 16 Old 07-30-2007, 12:33 PM
Brian's 97 ZJ
Brian's 97 ZJ's Avatar
Johnboy,
No, you shouldn't need to remove the engine to change the head gasket.
In order to get the valve cover off you will probably need to remove the plastic vacuum connector nearest to the cowl. It is probably a good idea to buy a new one since that one is going to be brittle and will likely break apart. Once that connector is out you should be able to lift and twist the cover off.
Head bolts are reusable once and if they have already been reused there should be a dab of bright paint on them to indicate such. If you are in doubt, buy a new set of bolts. Watch the torque pattern and spec; they are not all the same.
This will be a good time to check your exhaust manifold for cracks and to change that gasket as well.
Good luck!
- Brian
For some reason, being a member of the
just isn't as cool... Member #1
Brian's 97 ZJ is offline
post #14 of 16 Old 07-30-2007, 12:36 PM
cmonson
also, while you have the head off, I would deffinately change the timing chain.
cmonson is offline
post #15 of 16 Old 07-31-2007, 01:44 PM Thread Starter
johnboy2007
thanks for the replies everyone.
I've managed to track down a manual via ebay, and will give it a go once I,ve read it.
I have noticed you need a special tool to remove head bolts as these have splines on them. Since I'm based in the uk, most auto shops do not stock GC parts. Anyone know where I can locate this specialist tool?
4.7l oill fill spout gunk! Head Gasket? Cracked Head? kc8ztw ZJ Grand Cherokee Forum 10 10-29-2009 11:49 AM
Will a cracked head or head gasket...... jpl ZJ Grand Cherokee Forum 2 03-04-2009 09:35 AM
Head Gasket BRayf78 ZJ Grand Cherokee Forum 17 04-24-2008 09:30 AM
head gasket gone? darrenharris1@s ZJ Grand Cherokee Forum 7 01-07-2008 06:48 PM
How Much For A New Head Gasket? Briandl ZJ Grand Cherokee Forum 8 05-23-2007 12:18 AM
