Engine mounts. - JeepForum.com
post #1 of 4 Old 01-25-2005, 08:21 PM Thread Starter
HardStepper
Engine mounts.
Hi,
i have a '95 ZJ V8 and for couple of weeks there have been a thumping sound when accelerating/deccelerating on low speeds, 2-3 times a day. Might it be engine or tranny mounts? How could i check them? Also there aren't any instructions in Jeep manuals i have, how to replace them. Can i do it myself or does it need any special tools? How much might average worksop charge for replacing them, if it's too comlicated to do it on my own.
Thanks.
'95 ZJ V8 QuadraTrac
Bilstein shocks
Rancho steering stabilizer
MSD 8.5mm sparkplug wires
K&N airfilter
HardStepper is offline
post #2 of 4 Old 01-26-2005, 04:37 PM Thread Starter
HardStepper
No one has replaced engine/tranny mounts?
Forgot to mention, that there is vibration sometimes, when stnding behind red traffic light. When i put shifter to Neutral and press accelerator, it smoothens.
Bilstein shocks
K&N airfilter
post #3 of 4 Old 01-26-2005, 09:01 PM
jeepholic
jeepholic's Avatar
Have a friend rev the car hard a few times and watch the engine, if it jumps out of it's skin you need motor mounts, you can visually inspect the tranny mount. The motor mounts are easy to change.......if you have changed motor mounts before.
You need to jack up the engine from the bottom.
I use a Jeep
You drive a car
Big difference.
94 I6 ZJ at 4", 33's and front locker and 4.11 gears. Swampy Bypass.
Black Jeep Club Member Ver. 2 #51
jeepholic is offline
post #4 of 4 Old 01-26-2005, 09:23 PM
Meerkat
The Haynes manual has a very good step by step write up on how to inspect and replace motor mounts.
If you installed your shocks yourself, you have all the ability necessary to change your motor mount.
HTH
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
Vibes...Engine Mounts? AgitatedPancake ZJ Grand Cherokee Forum 2 01-21-2007 04:28 PM
Engine and trans mounts matts98ZJ ZJ Grand Cherokee Forum 1 07-25-2006 08:47 PM
Engine mounts?? Trusty ZJ Grand Cherokee Forum 3 06-11-2006 05:06 PM
Engine Mounts DTorres1978 ZJ Grand Cherokee Forum 10 07-15-2005 10:49 AM
Engine Mounts? hoot_tastic ZJ Grand Cherokee Forum 4 10-10-2004 11:41 AM
