engine light help! - JeepForum.com
post #1 of 7 Old 11-17-2003, 08:34 PM Thread Starter
pygocentrus
engine light help!
i broke my driveshaft for my 4x4 (under the steering wheel), and when i took it off, my engine light came on. will it turn back off when i replace the driveshaft, or what do i have to do?
98 GC limited 5.2 4x4
mods: 3 chamber magnaflow
upcoming mods: throttle body, intake, and headers, 3" lift, tires, and system (if I can save enough $)
pygocentrus is offline
post #2 of 7 Old 11-17-2003, 08:48 PM
BIGJMCCONNELL
1977 CJ7
I don't think there are any sensors that would notice the drivshaft missing. Have you done anything else to it lately? After you get it back together disconect the battery for a couple mins to reset the computer. That will reset the light i believe. If it comes on again you have some other problem to address.
The best way is to plug it into a diagnostic computer and get the error code.
--John
1977 CJ-7 with Ford 302 engine
2.5 inch springs Matkins Frame with 1.5 inch body lift and all Fiberglass body D30/M20 w/3.54 gears, Moser 1-piece and Rear Aussie Locker, Jeep T-18w/Dana 20 and 35" tires Dual Flowmaster Exhaust, 6 point roll cage, OBA and a bunch of other stuff.
BIGJMCCONNELL is offline
post #3 of 7 Old 11-17-2003, 09:40 PM Thread Starter
pygocentrus
how do i get the error code? does it cost anything? my budget is shot since the driveshaft and other stuff.
post #4 of 7 Old 11-18-2003, 01:13 AM Thread Starter
pygocentrus
hmm, the check engine light isnt on anymore.....
post #5 of 7 Old 11-18-2003, 02:51 AM
thephantum
thephantum's Avatar
1997 XJ Cherokee
Well, the light is off now so the point is kinda moot....
I don't know if you have Auto Zone's there, but they will pull codes for you for free. I'm not sure if Napa does it as well. You can also get a real basic code reader for around $150 or so...problem is you just get the code. I have an book that I bought with my FSM that has all the codes and what they mean. I'm sure that stuff is online somewhere though.
Rock On!
Steve
thephantum is offline
post #6 of 7 Old 11-19-2003, 08:53 PM
Trevor Khoury
I have a 93 gc 5.2 and my viscous coupler is broken in my transker case. My part time fix to this was to take off my drive shaft and I have not had any lights come on from that. It is also pretty cool to smoke the rear tires next to some import car and say that it is completly stock. So I would say that it is taking your driveshaft out is not causing the light to come on.
Trevor Khoury is offline
post #7 of 7 Old 11-19-2003, 11:18 PM Thread Starter
pygocentrus
yeah its weird, the light went off and never came back on. so i guess it was a freak accident or something.
Check Engine Light On: 1995 Jeep Grand Cherokee Limited 4x4 4.0 Engine Keith1975 ZJ Grand Cherokee Forum 7 11-04-2014 09:31 PM
Power Washed Engine - Check Engine Light on Now Davis87YJ ZJ Grand Cherokee Forum 31 08-11-2008 08:17 AM
0 oil pressure and no check engine light? Also what trigers major check engine fault SPL Tech ZJ Grand Cherokee Forum 9 01-08-2007 07:28 AM
check engine light, engine losing power kemicalburns ZJ Grand Cherokee Forum 21 05-27-2005 01:49 PM
Washed engine, now stalling with engine light on skaer ZJ Grand Cherokee Forum 3 07-14-2003 11:40 AM
