Engine Issues or Sumthings Up..... - Page 2 - JeepForum.com
post #16 of 23 Old 07-16-2011, 08:55 AM
JS97ZJ
The horn relay is more than likely the least used relay in the Jeep. By using that relay to swap out tha ASD or fuel pump relay (which get constantly used) can determine if one of those were giving u the problem.
JS97ZJ is offline
post #17 of 23 Old 07-16-2011, 09:02 AM Thread Starter
KillaJeep4569
2006 WK
Understood.
What is the Hall effect sensor for?
KillaJeep4569 is offline
post #18 of 23 Old 07-16-2011, 09:22 AM
JS97ZJ
The hall effect sensor is the Cam posistion sensor (inside the distributor).
It sets up injector timing with the PCM.
JS97ZJ is offline
post #19 of 23 Old 07-16-2011, 09:27 AM
JS97ZJ
NEVER try to adjust the dwell by turning the distributor. It's computer controlled. Turning it will f up the fuel timing which can only be correctly adj. by the dealership.
JS97ZJ is offline
post #20 of 23 Old 07-16-2011, 09:35 AM Thread Starter
KillaJeep4569
2006 WK
well the mech replaced it supposivly then unreplaced it. is that ok? Cuz he thought it was the problem
post #21 of 23 Old 07-16-2011, 09:43 AM
JS97ZJ
no problem
JS97ZJ is offline
post #22 of 23 Old 07-16-2011, 09:45 AM Thread Starter
KillaJeep4569
2006 WK
no problem
Thanks, How good is it to do the injector mod for this jeep?
Also what diff oil should i use front n rear
post #23 of 23 Old 07-16-2011, 09:54 AM
JS97ZJ
I was going to do the injector mod myself just haven't gotten to it yet. A lot of guys here have gotten good results with it along with replacing the intake manifold with a WJ intake.
I've been using full synthetic diff fluid as replacement oil, less changes, and wear on the gears. If you use it for towing adding the recommended modifier also would be required.
JS97ZJ is offline
engine oil issues - solutions? murray00 ZJ Grand Cherokee Forum 5 12-26-2009 05:51 PM
Check Engine Light w/ shifting issues charger_340 ZJ Grand Cherokee Forum 3 06-28-2008 08:11 PM
Engine Light is On - Tranny issues on the Horizon? swataz ZJ Grand Cherokee Forum 9 02-18-2008 09:23 PM
two 4.0 engine issues goldenjeep17 ZJ Grand Cherokee Forum 1 01-30-2007 08:29 PM
Sentry Key/Engine Start Issues cpferris ZJ Grand Cherokee Forum 1 05-06-2004 01:01 PM
