Engine Issues or Sumthings Up..... - JeepForum.com
post #1 of 23 Old 07-13-2011, 10:34 PM Thread Starter
KillaJeep4569
2006 WK
Hey guys I went fishing today and as I was coming off the beach the truck started to do the bucking and etc...... Too me every time it bucks I can smell oil being burnt up. Like oil you smell with a bad head gasket. I dont see smoke out of the muffler or under the hood.
As I got off the beach and on the road, she did it a few more times the bucking. Engine wouldnt start, open hood and play with that 3 prong connector every1 says is the issue.
As you hear the engine buck it sounds like a dieing engine, one that isnt getting gas, or something is in the gas, bucks, knocks, kicks, clanks, etc... i dont let it go for a few secs before shutting off. And then try to start, she does what I just stated and dies instantly
Then as I was driving home, I lost engine HP and power. She was like riding on what I would say 3 mb 4 cylinders. I would rev the engine she sounds like a dieing car, and an engine trying to gasp for air, car wouldnt go over 50 mph, if I tryed to gun it she just high revved and car would go nowhere, like she was in neutral.
No Check engine light on dash, Just did tune up months ago replaced everything I thought of. oil change on the regular, dont see any oil leaks on floor. Only flashing light I see is on that Cpu diagnostic with the pic of truck n small square in engine bay is flashing. Dont know what that means.
Any ideas before I bring to shop? Thanks guys
KillaJeep4569 is offline
post #2 of 23 Old 07-14-2011, 08:20 AM Thread Starter
KillaJeep4569
2006 WK
Nobody has anything???
post #3 of 23 Old 07-14-2011, 08:29 AM
JS97ZJ
I would start with checking into your o2 sensors an the wires leading to the PCM. Did you kick up a lot of sand on the beach? When was you last tune up? Any codes?
JS97ZJ is offline
post #4 of 23 Old 07-14-2011, 09:30 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
sounds trans related. checked your trans oil level lately?
ratmonkey is offline
post #5 of 23 Old 07-16-2011, 07:37 AM Thread Starter
KillaJeep4569
2006 WK
Trans Oil level good.
No codes, Just did tune up about 6 months ago. new everything.
post #6 of 23 Old 07-16-2011, 08:05 AM
ZeeJay1997
Sounds a little like the fuel pump relay. Swap it out with the horn relay and see if it improves. Are you sure it's not fuel you are smelling?
The three prong connector? There are three connectors on the PCM that give a lot of problems. Wiggle them while the engine is running and see if anything changes.
ZeeJay1997 is offline
post #7 of 23 Old 07-16-2011, 08:09 AM Thread Starter
KillaJeep4569
2006 WK
the 3 prong PCM thing is False. We sat there for 1hr straight and played with them plugs Nothing. Not sure why the car bucks and does what they say, but to me its not the PCM
Fuel Pump relay, I will replace
But why the Horn Relay??
Could this also be from a Clogged Cat or exhaust?
When you Rev the Vechile, in Neutral you hear the engine gasp for air, a deeeep rev it has, and itsnt higher than 4200 RPM
Car cannot go over 55 MPH or it just High revs and is like in neutral.
Car has No Low End power period!
post #8 of 23 Old 07-16-2011, 08:11 AM
JS97ZJ
Not being able to go over 50 would indicate a bad cat.
Did you bottom out on the beach? Look for exhaust damages......? Are we getting the whole story here? Did you see if it could float or do some deep sea exploring?
JS97ZJ is offline
post #9 of 23 Old 07-16-2011, 08:12 AM Thread Starter
KillaJeep4569
2006 WK
Dude you serious? Whole Story??
why would anyone Lie about trying to get help? Make some sense please
And Yes I think my cat is clogged
post #10 of 23 Old 07-16-2011, 08:20 AM
JS97ZJ
I'm not ridiculing, or saying that your lying .....CHILL,
I'm honestly trying to help out here with only getting descriptives of your problem.
Try thumping on the cat and listen for loose parts...
JS97ZJ is offline
post #11 of 23 Old 07-16-2011, 08:22 AM Thread Starter
KillaJeep4569
2006 WK
I thought I was elaborate and descriptive on my problem.
cat has **** shaking inside, Will replace.... What do you think of driving with out one for a few days?
post #12 of 23 Old 07-16-2011, 08:27 AM
ZeeJay1997
Because it is not essential to get from point A to point B. Saves you from buying a relay you don't need.
BTW, people here want to help you and are not out to get you. JS didn't deserve what he got and you should apologize. I'm done with this post.
post #13 of 23 Old 07-16-2011, 08:28 AM Thread Starter
KillaJeep4569
2006 WK
Say that again? Im confused.....
Why replace a Horn relay again?
post #14 of 23 Old 07-16-2011, 08:41 AM
JS97ZJ
The PCM sets fuel mixtures for the engine performance using the o2 sensors. Some guys have ran their rigs without a cat in hopes of better exhaust flow without any adverse effects. It probably would run alot better than it's running now.
A new cat that has the down stream sensor port runs about $150.
Zee was trying to determine if your problem was ASD or fuel pump related.
JS97ZJ is offline
post #15 of 23 Old 07-16-2011, 08:43 AM Thread Starter
KillaJeep4569
2006 WK
But what does his statement mean?
And why replace the Horn relay?
I also know how a cat works... Also I can get a cat for 69 bucks.
engine oil issues - solutions? murray00 ZJ Grand Cherokee Forum 5 12-26-2009 05:51 PM
Check Engine Light w/ shifting issues charger_340 ZJ Grand Cherokee Forum 3 06-28-2008 08:11 PM
Engine Light is On - Tranny issues on the Horizon? swataz ZJ Grand Cherokee Forum 9 02-18-2008 09:23 PM
two 4.0 engine issues goldenjeep17 ZJ Grand Cherokee Forum 1 01-30-2007 08:29 PM
Sentry Key/Engine Start Issues cpferris ZJ Grand Cherokee Forum 1 05-06-2004 01:01 PM
