Engine interchange? - JeepForum.com
post #1 of 25 Old 06-07-2012, 05:35 PM Thread Starter
94Jeap
Engine interchange?
can any one tell me what the differences are be tween a 94 gc 4.0 engine, and later 4.0 engines?
the reason I'm asking is that i'm looking for a used engine for a 94, and I've found a good price on a 98 engine. the salvage yard tells me that the two engines won't match.
I was wondering if the main difference is distributorless ignition on the later engine, and could I just pull the cam sensor and install the distributor in its place? Or am I overlooking a larger fitment problem? (possibly a firing order change, coolant flow changes, missing bolt holes etc...)
Has anyone used the later engine in the earlier body?
any help is appreciated
94Jeap is offline
post #2 of 25 Old 06-07-2012, 06:16 PM
Jerbear0612
They should fit fine as long as both engine were backed by the same tranny
Jerbear0612 is offline
post #3 of 25 Old 06-07-2012, 06:18 PM
gactech
98 has the obdII I don't think the 94 had it.
gactech is offline
post #4 of 25 Old 06-07-2012, 06:27 PM
RazorbackZJ
1994 ZJ
No car had obdII until 96.
RazorbackZJ is offline
post #5 of 25 Old 06-07-2012, 07:01 PM
edpmedic
That's true I think you would need to change wire harness computer and some other stuff. It could be s nightmare. Maybe out would be easier to rebuild yours, what's wrong with it?
Never4get those who gave their lives on 09-11-01 WTC and Pentagon. FDNY-EMS-NYPD-PAPD. Also those who are still dying.
_______________________________________________
"Freedom is never voluntarily given by the oppressor; it must be demanded by the oppressed."
Martin Luther King, Jr.
"Always aim at complete harmony of thought and word and deed. Always aim at purifying your thoughts and everything will be well."
Mahatma Gandhi
Feel the Sunshine on your face
edpmedic is offline
post #6 of 25 Old 06-07-2012, 08:35 PM
SchizophrenicMC
2016 JK Wrangler
I don't see why a 98 engine would be different from a 97 engine, which I know is identical to a 94 engine. Am I missing something here?
Signature rules are dumb
SchizophrenicMC is offline
post #7 of 25 Old 06-07-2012, 09:12 PM
rm2001wj
rm2001wj's Avatar
I was wondering if the main difference is distributorless ignition on the later engine, and could I just pull the cam sensor and install the distributor in its place? ............
Distributorless ignition was not used until the 99 and later WJs. So that won't be a problem.
rm2001wj is offline
post #8 of 25 Old 06-07-2012, 09:33 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
1990-2001 XJ Cherokee and 1993-1998 ZJ Grand Cherokee engine blocks interchange.
Simply remove and re-install on the donor engine block the original intake/exhaust, head, fan belt driven accessories, motor mounts, transmission, OBD sensors, distributor, flywheel/flexplate, or other original parts, as needed or required.
2000+ TJ and any WJ engines do not interchange and will not fit.
The junkyard is talking about a 100% bolt in engine swap.
CJ7-Tim is offline
post #9 of 25 Old 06-07-2012, 09:57 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
2000 & 2001 xj motors, 1999-2006 tj motors, 1999-2004wj motors will not fit due to using different motor mounts on the block.
A 1998 zj motor will bolt on, but the flex plate and many sensors are different.
ratmonkey is offline
post #10 of 25 Old 06-07-2012, 09:59 PM
SchizophrenicMC
2016 JK Wrangler
Originally Posted by CJ7-Tim View Post
1990-2001 XJ Cherokee and 1993-1998 ZJ Grand Cherokee engine blocks interchange. Simply install the original intake/exhaust, head, fan belt driven accessories, motor mounts, transmission, OBD sensors, distributor, flywheel, or other required original parts, as needed, onto the donor engine block.
The junkyard talking about a 100% bolt in engine swap.
See, that's what I was thinking. Of course, my swapping experience is mostly with Nissans, so while I'm familiar with them, I don't know all the nuances of Jeeps.
post #11 of 25 Old 06-08-2012, 09:22 AM
CJ7-Tim
CJ7-Tim's Avatar
Rat,
2001-01 XJ engine block are compatible and will interchange with any 1990-2001 XJ Cherokee and with any 1993-1998 ZJ Grand Cherokee engine blocks.
CJ7-Tim is offline
post #12 of 25 Old 08-31-2012, 06:40 AM
hautewheeler
finally searched long enough to find it!
Been searching for a couple of hours for this information, and don't mean to be a thread pirate, but my question is similar to op's.
So just to be sure, a 1992 cherokee 4.0 engine block will work in my 1995 grand cherokee, I just have to swap from the head up and all of the peripherals?
The 1992 cherokee has a five speed manual, and the 95 gc has the automatic, is there any issues with the bellhouse pattern ?
Thanks guys..
hautewheeler is offline
post #13 of 25 Old 08-31-2012, 02:57 PM
SchizophrenicMC
2016 JK Wrangler
Thanks guys..
The manual transmission has a bellhousing, the automatic does not; it was designed to mount to the 4.0 block, whereas the manual was used for multiple engines and patterns, so it uses a bellhousing as an adapter.
As far as I know, you shouldn't have to swap the head or anything, but the peripherals may need to be swapped over. (If any peripherals have different mounting locations between models, you'll have to use model-specific components to mount them, possibly including the head and/or block)
tl;dr the engine should bolt in, but the accessories probably won't.
post #14 of 25 Old 09-04-2012, 03:13 AM
hautewheeler
Originally Posted by SchizophrenicMC View Post
The manual transmission has a bellhousing, the automatic does not; it was designed to mount to the 4.0 block, whereas the manual was used for multiple engines and patterns, so it uses a bellhousing as an adapter,
That's great information, thank you.. I did not know that!
post #15 of 25 Old 03-05-2015, 04:02 AM
rodneyjohnson
how big
I have a86 comanchee truck with the 2.8 five speed.can I go any bigger on motor without changing tray and transfer
rodneyjohnson is offline
engine swap
93 and 94 4.0 interchange vegte44 ZJ Grand Cherokee Forum 2 01-30-2012 05:00 PM
1997 Jeep Grand Cherokee engine harness interchange cjseipp ZJ Grand Cherokee Forum 0 02-17-2011 05:56 PM
4.0 ECM Interchange?????? SD-Pimpin ZJ Grand Cherokee Forum 2 01-06-2010 11:30 AM
4.0 vs 5.2 transmission interchange? Area.3.Fiftyone ZJ Grand Cherokee Forum 3 10-12-2009 01:42 PM
4.o engine and auto tranny interchange info needed obsdiner ZJ Grand Cherokee Forum 1 02-18-2009 06:40 PM
