Engine drain plug - JeepForum.com
post #1 of 21 Old 05-28-2006, 03:19 PM Thread Starter
///BHRpowered
///BHRpowered's Avatar
Engine drain plug
So I knows its a noob question and all, but everything just says "lower left side of block" well that doesn't help, especially since the horrible picture seems to match up with the right side.
Anyway I don't even know what 1 looks like, but also, where is it on the 4.0?
"A dark and bitter chill fills the air. once thriving life wallows away into ash as he slithers past, the very stars themselfs part to make way for his haunting, yet oddly claim arrival. Bhr approaches." - Hatter
"But i have to say, BHR's rants go hand in hand with moring coffee to get my day started - RXL"
Admin -
///BHRpowered is offline
post #2 of 21 Old 05-28-2006, 03:31 PM
GreenDean
GreenDean's Avatar
If your looking for the coolant plug...
Look at the #5 cylinder exhaust port.
Follow the block straight down from that point.
Theres your plug.
GreenDean is offline
post #3 of 21 Old 05-28-2006, 04:08 PM
-Joe-
-Joe-'s Avatar
http://jeephorizons.com/tech/radiatorflush.html
I thought after 96 or so they moved the coolant sensor for the gauge there, And I also thought there was only 1 plug so mabye im wrong about that.
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
post #4 of 21 Old 05-28-2006, 04:32 PM Thread Starter
///BHRpowered
I'm fairly certain the coolant temp sensor was relocated, unlessthere are 2 of them, but I'm thinking of the 1 on the thermostat housing/water outlet.
Admin -
post #5 of 21 Old 05-28-2006, 04:40 PM
-Joe-
-Joe-'s Avatar
The one on the thermostat housing is the computer, theres a second for the inside gauge.
- Joe -
-Joe- is offline
post #6 of 21 Old 05-28-2006, 05:20 PM Thread Starter
///BHRpowered
so JF dream team, how the hell do I get to this plug. no matter what angle I take I can't seem to get to it, atleast without removing the intake manifold or the exhaust. My jacks only go so high
Admin -
post #7 of 21 Old 05-28-2006, 05:35 PM
-Joe-
-Joe-'s Avatar
I couldnt get mine out so i left it and just did a good flush
- Joe -
-Joe- is offline
post #8 of 21 Old 05-28-2006, 05:41 PM
GreenDean
GreenDean's Avatar
Agreed.
Theres no need to remove it.
You wont get anything out that you wouldn't with a good flush.
Or buy a taller jack.
post #9 of 21 Old 05-28-2006, 08:51 PM
oilcounter
I don't have any pics to demonstrate, but if you crawl under you'll see a rectangular with a Hex bolt in a horizontal position.. That's the Drain Plug.. There isn't anything else down there. Trust your gut..
You're probably ready to change your oil now..Get a drain pan from "Meglo-Mart" and some Mobil 1 synthetic 10w-30 and a oil filter and you will be on your way..
2000 JEEP GRAND CHEROKEE I-6 (WJ)
All stock except for Mopar 3 disc In-dash CD player
Michelin M/S LTX 255/70/16
Metallic Taupe Jeep Club Member #15
oilcounter is offline
post #10 of 21 Old 05-28-2006, 08:56 PM
GreenDean
GreenDean's Avatar
He's talking about coolant. Not oil.
post #11 of 21 Old 05-28-2006, 10:01 PM Thread Starter
///BHRpowered
oil isn't a problem, the hell with finding that damn bolt and trying to get to it. I just pull the lower radiator hose off, then used a shop vac to suck everything out of the overflow tank using the radiator overflow hose, worked pretty well.
Admin -
post #12 of 21 Old 05-28-2006, 10:12 PM
zaq123
zaq123's Avatar
1941 JK Wrangler
Well it isn't engine oil plug thread but I just want to see if anybody here uses this thing. It makes oil change so much easier and virtually eliminates any mess
http://www.4x4xplor.com/fumoto.html
zaq123 is offline
post #13 of 21 Old 05-28-2006, 10:20 PM
Meerkat
No, I usually use a big tub to catch my oil with. Milk jugs aren't a bad idea, but they do tend to leak around the cap....
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
post #14 of 21 Old 05-29-2006, 04:19 PM Thread Starter
///BHRpowered
I have just a plastic oil thing I got for 5 bucks somewhere, but I put it on top of a block so its right there, zero mess.
However, I store all my old oil, gear lube, transmission fluid whatever is 1 of those deer park 5 gallon water drums, good strong storage and lets me make only 1 trip every year or so
Admin -
post #15 of 21 Old 05-29-2006, 04:32 PM
Meerkat
Actually, I was being deliberately obtuse. Zaq was really wanting to point out the quick drain valve gizmo. You can get it at most any autoparts store for pretty cheap. The idea is you replace your drain plug with this baby, then, when it's time to drain the oil, you stick a tube on it open the valve (no tools needed) and bob's yer uncle!
It seems a good idea, but I have a hard time trusting anything that easy to open and drain the life fluid out of my Jeep.
Warren
Meerkat is offline
Engine Block Drain Plug 4.7L V8, Where is it? lvdent ZJ Grand Cherokee Forum 1 08-09-2009 10:29 AM
engine oil change time - no drain plug 4x4traveler WK Grand Cherokee & XK Commander Forum 7 11-18-2008 07:34 PM
Engine block drain plug shdwoflyte ZJ Grand Cherokee Forum 3 09-23-2007 04:55 PM
Coolant Engine Drain PLug -Joe- ZJ Grand Cherokee Forum 3 02-20-2005 03:56 PM
6 Cyl engine coolant drain plug . . . ? Humberto Benavides ZJ Grand Cherokee Forum 2 02-24-2002 10:55 PM
