Originally Posted by JackAysJake
New member here...this is my first post.
I have a 1995 Jeep Grand Cherokee I6 4.0L.
recently it seems to want to loose power...as in i turn the key off momentarily. let off the gas and give it a little more gas, or just wait and it will seem to go away. seemed to be an electrical problem at first so i checked the battery and it is swolen, and corroded, so ill have to replace the terminals and battery, but also tried to hook up my obd1/2 reader because i am getting a check engine light. it will not connect. fuse maybe??? i know this sounds crazy but i put an aftermarket cd player in and i know how jeeps are have some power that has to run through the cd player... could this be a problem?
anyone know the blink codes in the jeeps?
thanks a lot guys/girls
Jake
To display codes cycle the ignition key On-Off-On-Off-On within three seconds. Count the number of flashes, first digit, pause then second digit will be displayed in a series of flashes. (2 flashes, pause, 1 flash = 21)
11 - No Crank Reference Signal At PCM (Crankshaft Position Sensor)
12 - Battery Disconnected Within last 50 Key-on cycles
13 - No Change In MAP Sensor
14 - MAP Voltage Too Low Or Too High
15 - No Vehicle Speed Sensor Signal
17 - Engine Is Cold Too Long
21 - O2 Sensor Signal At Center Or Signal Shorted To Voltage
22 - ECT Sensor Voltage Too Low Or Too High (ECT = Engine Coolant Sensor)
23 - Charge Air Temperature Sensor Voltage Too High Or Low (Intake Air Temp Sensor)
24 - Throttle Position Sensor Voltage Too High Or Too Low
25 - Idle Air Control Motor Circuit Shorted
27 - Injector Control Circuit Signal Not Responding Correctly.
31 - EVAP Purge Solenoid Circuit Open Or Shorted
32 - EGR System Failure
33 - A/C Clutch Relay Circuit Open Or Shorted
34 - Speed Control Solenoid Ciruit Open Or Shorted (Vacuum Or Vent)
37 - Torque Converter Clutch Solenoid Circuit Open Or Shorted
41 - Generator Field Not Switching Properly
42 - Auto Shutdown Relay Control Circuit Open Or Shorted Or No ASD Voltage
44 - Battery Temp Sensor Voltage Out Of Limit
45 - Overdrive Solenoid Circuit Open Or Shorted
46 - Charging System Voltage Too High
47 - Charging SYstem Voltage Too Low
51 - O2 Sensor Signal Stays Below Center (Lean)
52 - O2 Sensor Signal Stays Above Center (Rich)
53 - Internal PCM Failure
54 - Sync Pick-Up Signal Not Detected (Camshaft Position Sensor/Ignition Pickup)
62 - PCM Failure SRI Miles Not Stored
63 - PCM Failure EEProm Write Denied
55 End Of Codes
