Engine Caps Out - JeepForum.com
post #1 of 25 Old 06-02-2013, 06:32 AM Thread Starter
hozer
UPDATE: Engine Craps Out:---> Problem Solved!
My 96 Jeep Grand Cherokee 4.0 Craps out. I have 175K miles on my engine.
Now when I start my jeep it starts the stops. And When I start it again I'll be running down the street and then it sputters and I have to pump the gas pedal
and then my jeeps continue down the street. It seams to me it does it a low RPM also. Now could be the computer?
hozer is offline
post #2 of 25 Old 06-02-2013, 06:45 AM
ZeeJay1997
http://www.jeepforum.com/forum/f13/1...talls-1407423/
ZeeJay1997 is offline
post #3 of 25 Old 06-02-2013, 11:00 AM
JasonStebbins
First guess, fuel pump.
Poop
JasonStebbins is offline
post #4 of 25 Old 06-02-2013, 11:24 AM Thread Starter
hozer
Originally Posted by ZeeJay1997 View Post
Thanks for the heads I went and pulled the computer out cleaned the connectors and plugs and put it back together. Then went to wally world and bought those 1/2" wide 3 ft long lol zip ties. Pulled them so tight that superman cant pulled them off lol. Then I did the wiggle test and no changes YEA BABY!!!
The engine never never craped out but i will check again in a couple of days to make sure the ties are real tight. I hope it stays that way and does not start craping out again!
Thanks again bud for the heads up!
hozer is offline
post #5 of 25 Old 06-02-2013, 11:28 AM
JasonStebbins
Damn you ZeeJay!
Glad you got it fixed.
Poop
post #6 of 25 Old 06-02-2013, 11:30 AM
ZeeJay1997
chock up another one for the dirty dozen.
HOWEVER!, that is not a permanent fix.
post #7 of 25 Old 06-02-2013, 11:36 AM
JasonStebbins
You should be getting donations at this point.
It is until you want to fork over $275.00 for a Cardone.
Poop
post #8 of 25 Old 06-02-2013, 11:39 AM
ZeeJay1997
I gave 180 for mine at NAPA, but i had a jobber discount of about 40% because i asked for the "cuz" deal... and a military discount
post #9 of 25 Old 06-02-2013, 01:10 PM
Oldfrog
2007 WK
I agree with Zeejay, in that it's probably not a permanent fix....although I hope it is. I am beginning to suspect that the making and breaking of certain connections can eventually fry the PCM....or at least one of the components in it. My latest stalling issue seemed to be caused by a bit of oil and trash inside my distributor cap or maybe the coil wire being crossed on top of one of the plug wires on top of the cap.. Cleaned it all out...moved the wire and it's fine now. Who knows?
But hey...enjoy it while it lasts...eh ?
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #10 of 25 Old 06-04-2013, 04:51 PM
e_mac682
Its the faceplate that attaches to the body of the computer case, at least thats what mine is having problems with. Tried all the fixes mentioned and had it work for a couple of years. Now I am hosed since I have to get it emissions tested and they check for OBD resets. Well when the jeep craps out...it resets. Damn. So the computers that are online, they any good, or worth pulling the trigger on?
97 GCL LMTD
I6, 4.0L Stock 2WD
e_mac682 is offline
post #11 of 25 Old 06-04-2013, 05:30 PM Thread Starter
hozer
1 more question if my jeeps starts crapping out again after cleaning the computer and its connections is it fair to say its the computer that needs to be replaced?
hozer is offline
post #12 of 25 Old 06-04-2013, 05:37 PM
misfit77
Does it run at Full open throttle?
If so, i say its a sensor (MAP, AIT or so) My XJ with 4.0 had issues like this mostly at startup.
Apparantly the computer disregards any input from the sensors at FOT.
misfit77 is offline
post #13 of 25 Old 06-04-2013, 05:49 PM Thread Starter
hozer
Yes I was able to jump on it with no problems!
hozer is offline
post #14 of 25 Old 06-05-2013, 03:01 PM
misfit77
Codes dont give any report on sensors?
misfit77 is offline
post #15 of 25 Old 06-05-2013, 05:59 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
Lol, he oughta charge by now, him and JS
Originally Posted by HighLonesome
coralman is offline
