Engine Blown - We Can Rebuild, We Have The Technology, Just Not the $$$
| Spartan Lockers FREE SHIPPING Excellent Prices | DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97- | Mojave Cut & Fold Rear Bumper – Jeep Cherokee XJ |
#1 | |
hi all, thanks in advance for any help provided.
well i got a call from the girlfriend the other day with a question of why the motor just blew up and how far she could get. answer to the question, not far, which i found out after towing it home, working in the driveway in below freezing temps and finally clearing enough space in the carage to work and feel my hands....drum roll.... a snapped rod which sent the piston up and into the spark plugs and valves in cylinders 4 & 6, i think. i've gotten the rockers and pushrods out and i'm waiting for some money before i remove the head, replace the valves and hope that the cylinder walls aren't marred, or the cam broken, or god kows what else. there was so much sludge in the engine that there wasn't any liquid oil, which i love, because an engine rebuild is so much cheaper than an oil change on schedule, right??? ![]() anywhoo, i wanted to hear from those of you who have been through a 4.0L rebuild and have any guidance. i know in theory what to do but i haven't done a rebuild on this engine and i don't want to screw it up. are there any things i should look out for or maybe add or do to the rebuild so i can get a better than stock engine without having to drop a ton of cash? i want this to be my project over the next coming months and i wanto to do it right and do it once. any pictures would be extremely helpful, and thanks again for any help. ![]()
[B][I][CENTER][CENTER]All I Know Is My Gut Says Maybe.[/CENTER][/CENTER][/I][/B] |
#2 |
Can you say STROKER?
![]() Bore it out .030 over, use 258 (4.2L) crank and rods, and end up with a 4.7L powerhouse. I know when my 4.0 eventually dies, thats what I hope to do with it.
DD: 98 ZJ Laredo 5.2, all stock Wheeler/Beater: 93 ZJ Laredo 4.0, AW4, 231 conversion from 249 3" coil lift, JKS Adjustable Track Bar, JKS Quicker Discos, KOR lwr rad supt, Brush guard Colorado Jeep Club Member 242 (4.0L) |
#3 | |
zj tractor
ok you only need 4 things to fix this
1. stroker. 2. high performace rebuild 3. bore .030 over 4. and least importiant.... lots of $$. seriously, you can do a stock rebuild, or just get a new motor... but it would still be uber cool to do a stroker.
hard working private first class in the United States Marine Corps. Quote:
build thread:http://www.jeepforum.com/forum/f197/5-9-andys-1-ton-zj-build-american-standard-1056365/ |
#4 |
Whats the deal with all the sludge? How many miles are on the motor? Any interest in buying one from the for sale section? If I tore the top off an engine and saw a bunch of sludge and had a broken rod Id completely tear it down...which costs nothing. But I do understand that its darn cold in the drive.
Yes there are tons of good links on the net. Google search 4.7 stroker and 4.0 rebuild. Remember the 4.0 was in about every jeep so dont limit yourself to the grand forum. Id really like to know the miles and why all the sludge was in there. |
#5 |
i had my number 1 cylinder rod break on me i got a free 4.0 and just swapped it out and re used the good things from my engine... I would also think that if you broke 2 rods unless they disinigrated like my rod did they might have not hurt the walls... i personally would want to get it honed or bored out smooth tho... or if you live close i can give you my old engine with only one blown cylinder but the block is still in pretty good condition. you need to completely rebuild it tho because it has been outside un covered in rain and snow since march lol
94 ZJ I6 Second 4.0 as of 226k Aftermarket Intake, Flowmaster 40 series, Rear Discs 05 Kawasaki Ninja ZX-6R 636 just ridiculously fast 96 Nissan Altima 5 speed stock and probably keepin it that way aka the beater or commuter car who wouldnt buy it for a grand with how gas is |
#6 |
I went through this a year ago on my 95ZJ. Short story: Bad #6 cylinder on original 4.0L (cracked wall...water in oil... not fun). Picked up a used motor for $100. Dropped pan on 'used' motor and found most of #3 piston in bottom of pan (too far of a drive to take it back). Tore down entire motor. Machined head/block and honed cylinders. Polished crack. Engine rebuild kit... $600 later, I had rebuilt motor. My first. It's still running.
Could have saved some money on a good used motor, but I enjoyed putting the new 'used' one back together and I have a better feel on how everything works. Get a GOOD factory service manual for the JEEP. It will cover entire engine rebuild and other things. Well worth the money!... Good luck.
2008 Jeep Wrangler X (Hard Top) Incubus Off Road 511's with BFG 285/70-17 1998 Jeep Cherokee Sport 4.0L/AW4, Yakima Roof Rack |
#7 |
sludge = pennzoil
poor maintenance for an engine check a salvage, kiiji or craig list. heck you may even be able to pick up a whole jeep that's been totaled cheap I have 310,000 mile on my 5.2 ... so if I would have not change the oil. EVER. I would have saved almost 2 grand.. But I don't think my engine would have lasted this long.
94 Grand Cherokee ... 332,000 miles 5.2 liter 242 :) Rancho 5000 steering stabilizer |
#8 | |
1993 Grand Cherokee Limited, 5.2L Modified/Slightly Ported Kegger Air hat spacer Modified Throttle body Flowmaster muffler |
#9 |
in response to crazydrivinjoe, im in fairhaven mass so you aren't that far away, and thank you very much for the offer of the old block. and in response to the sludge question, yeah, basically neglect, i wasn't driving it so i wasn't up on the maintenance and i really ended up screwing myself. but to look on the brighter side, now i have my project jeep.
and to add insult to injury, on my 98 grand, the alternator died and left me stranded on the highway for almost 2 hours in below freezing temps, but i at least can use the one from my 95, so no money out of pocket. the whole idea of a stroker is pretty tempting, i just need to find someone local that can do the machine work for cheap. thanks for the ideas and comments, keep 'em coming, i can use them.
#10 |
oh yeah, it has about 185k miles on the engine.
#11 |
What year? New 4.0 shortblocks on ebay go for about $600.
98 Jeep GC 5.9 - Mopar intake, Mopar ECU, Edelbrock struts, lots of audio (see details) 89 MR2 MK1.5 - Body done, built 450whp 3sgte, 6 year project so far 89 MR2 SC - 317k! rims, cams, lsd, pulley, exhaust, intake, header, brakes, stereo, bushings... still going :) 74 CB360 - Lots of cool cafe stuff :D |
#12 |
If it was bad enough to do that, you probably need all new pistons, new cam & bearings, new crank bearings, new oil pump complete valve job and total machine job on the block to be sure, Go for a new / used engine, you'll save money & time, unless you need something to do for a few weekends.
2000 WJ 4.0L 42RE 242 TC 152,251 miles & counting |
#13 | |
throwing rods/sludge=fram filters with more than 8k miles on em. ![]()
-Platinum 98 ZJ Limited 5.9. 46RE/NV249 Quadra-Trac. AKA the Gasoholic. Lift in the works.... |
#14 | |
95% or more of the air, fuel and oil filters I and my immediate family have used have been Fram with ZERO failures due to a filter.
Russ 02 Dakota Quad Cab 4.7 5 spd 93 ZJ Stolen and wrecked Mar29/08 |
#15 |
Do a google search, Frams are cheaply made filters, they work but don't run them for more than 3000 miles. I found an article where a guy did an unscientific but good writeup on filters. he bought different kinds & cut them open to see how they're built. The cheapy Frams had a cardboard bypass valve, just a flap where the better filters including the higher grade frams had a metal bypass. seems to me a cardboard one probably has leakby letting dirty oil bypass it.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
