Engine Bay Wire Cleanup - JeepForum.com
post #1 of 6 Old 09-23-2013, 05:22 PM Thread Starter
ELMCZJ95
So I have a bit of a mess around my battery terminals, wiring for 2 sets of lights with relays, and I was wondering what methods you guys have used to consolidate the wires and make it look more compact? I've done a ton of searching on the forum and the fuse boxes/distribution blocks seem much too complicated for me, I only have a basic knowledge on wiring. So what are you guys doing to clean up your wires?
Jeep Grand Wrangler Build Thread: http://www.jeepforum.com/forum/f13/jeep-grand-wrangler-build-1398775/#post13935376
ELMCZJ95 is offline
post #2 of 6 Old 09-23-2013, 11:29 PM
zjosh93
When I was trying to put an electric fan in front of my 4.0 I found a relay/fuse block on a Saab that held two relays, four ATO fuses, and two Maxi fuses. As for wiring I love corrugated tubing sealed at the ends with adhesive lined shrink wrap.
zjosh93 is offline
post #3 of 6 Old 09-23-2013, 11:42 PM Thread Starter
ELMCZJ95
Do you have any writeup on the fuse box install? I'm literally lost with how to put those in.
ELMCZJ95 is offline
post #4 of 6 Old 09-24-2013, 07:50 AM
x10radsponge
Some are using these... if it is just the wires you are trying to clean up. Also may consider a weather proof junction box from HD or Lowes and put your relays, etc in there.
x10radsponge is offline
post #5 of 6 Old 09-24-2013, 07:52 AM
x10radsponge
Quick search found this weather proof box for trailers.
post #6 of 6 Old 09-24-2013, 08:10 AM
zjosh93
No write up, sorry, it was awhile ago. It's pretty easy. Each pin for the relays and fuses has a single wire connector that you can remove from the box by using a pick to release a tab or clip usually. Then you can solder your new wires to the connector. You can also just leave a few inches of wire attached and splice to that. The mounting was pretty simple.
This is the box I used. I just googled it and found a pic. Looks like I was misremembering the fuse count. It's from a Saab 9000 and it was on the fender. It has an easy mounting bracket and a nice weatherproof clear cover.
zjosh93 is offline
