Energy suspension 1.75 lift - JeepForum.com
post #1 of 5 Old 12-09-2011, 04:01 AM Thread Starter
totalalign12
I picked up a 1.75" bb. I put all the skid plates off a uplander from the salvage yard. The springs have a 100,000 miles on them, so I may gain a inch or inch and a half. My new Rancho shocks should work, though I'll check the travel. My question is do I use only the pretty new spacers? Or use them in conjunction with the factory isolator? Of course there's no instructions.
totalalign12 is offline
post #2 of 5 Old 12-09-2011, 04:03 AM
MilanJeep
MilanJeep's Avatar
You can do it either way. I'd leave the isolator in for more lift
98 5.9 ZJ - 4.5" lift, 33x12.50 MT/R Kevlars
02 Z06 - Supercharged, E85, lots of rwhp, built and tuned by me
Milan
MilanJeep is offline
post #3 of 5 Old 12-09-2011, 05:31 AM Thread Starter
totalalign12
I'm concerned my shocks are going to be short. I was really wanting to keep the lift at 2"
post #4 of 5 Old 12-09-2011, 07:57 AM
somebody5788
1994 ZJ
The isolator will help keep things quieter, I'd assume the 1.75" was assuming you were using the stock isolators.
2006 Honda 919 - Summer Daily
1994 Jeep ZJ - RC Long Arms | RE 4.5" springs | Bilstein 5100's | RE SS brake lines | Falken 31x10.5-15 tires | Flatland 4x4 bumpers | Summit Soft 8's 15x8 3.75 BS wheels
somebody5788 is offline
post #5 of 5 Old 12-09-2011, 05:12 PM Thread Starter
totalalign12
You guys were right. I just left the isolator in. I kept it against the spring were it was, and stuck the 1.78 bushing on the front. It was quite a bit bigger then the rear. I spaced out measuring the rear, but it was a little smaller. These ZJs sat lower in the front. So Now it sits level. With the insulators and Energy suspension kit its an easy 2 " lift.
The track arm lined up nice, sway bar links were no problem. Shocks have tons of travel. Rides and drives perfect. Thanks 12
