endless probs! - JeepForum.com
post #1 of 10 Old 08-21-2009, 06:28 AM Thread Starter
bmx_hb_guy
endless probs!
98 gc 4.0
sooo right now im tight on money an my jeeps needing a good deal of work!!
it cuts off randomly but hasnt done it in a day or 2, very rough idel, and has a strong lack of power right now when i go to get on the gas????
recently iv changed crankshaft pos. sensor,spark plug wires, sparkplugs, air filter????
i really need to fix these probs but cant find any codes or anything????
how would i go about checking the tps or ignition coils or computer???....also goin to get fueil pressur test next payday.
ty yall
93 wrangler 2.5l, 2in lift shackels, 31's, eagle alloy 186,and a flowmaster 44
98 zj 4.0 straight 6, 4in f<r lift, adj. trak bars, rustys sway bar quik discos, skyjacker shocks, rancho steering stabalizer, 32x11.50 daytons, straight piped, 2 12" pioneers,
I DO ALL MY OWN WORK!
AND YES IM 17 BUT THIS JEEP AINT DADDYS MONEY!
bmx_hb_guy is offline
post #2 of 10 Old 08-21-2009, 07:17 AM
ezflip
ezflip's Avatar
2011 JK Wrangler
You should clean your Idle Air Control valve and Throttle Body. $5 can of Throttle Body cleaner and about an hour of your time, there is a write up in the FAQ. That should help the rough idle. I would also replace the TPS. It was $35 a month ago when I put one on my buddies Jeep, but when I bought mine (havent put it in yet) it was $46.99. Not sure why there was a 30% increase in price for the same exact part but still, anything under $50 is cheap on a Jeep
~James
ezflip is offline
post #3 of 10 Old 08-21-2009, 05:19 PM
SouthSeaPirate
^ X2
But Id try SeaFoaming before I go buying parts.
Where you at in FL?
SouthSeaPirate is offline
post #4 of 10 Old 08-21-2009, 05:30 PM
ZeeJay1997
Try swapping the fuel pump relay and ASD relay with the horn and wiper relays.
ZeeJay1997 is offline
post #5 of 10 Old 08-21-2009, 05:39 PM
SouthSeaPirate
I thought relays worked or didnt work. I suppose I thought wrong.
post #6 of 10 Old 08-21-2009, 07:20 PM
ZeeJay1997
Relays are two part devices, the coil and contacts.
The contacts often build up carbon from continuous use or overloading from faulty components, causing high current draw (resistance) at the contacts resulting in low voltage to the loads and/or intermittent contact.
The coils can also go bad either completely or intermittently.
They all eventually go bad, especially the fuel pump and ASD relays because they are continuous duty. The ASD powers the coil, O2 sensor heaters, and injectors.
post #7 of 10 Old 08-22-2009, 10:44 AM Thread Starter
bmx_hb_guy
iv already cleaned my iac vaulve and throttle body.....and im gonna try swapping my relays here in a few ill let yall know how it works ty
also how would i test my tps?
post #8 of 10 Old 08-23-2009, 10:41 AM Thread Starter
bmx_hb_guy
sooo i swaped the relays yesterday and aint had a prob. sence!!!
thanks guys
post #9 of 10 Old 08-23-2009, 01:18 PM
ZeeJay1997
Even a blind hog can find an acorn every now and then.
post #10 of 10 Old 08-23-2009, 01:51 PM
Virmagicus
Virmagicus's Avatar
Quoted for truth.
Jeff
Virmagicus is offline
Some Probs with everything DCoggy ZJ Grand Cherokee Forum 3 12-11-2009 01:10 AM
AC probs sandman ZJ Grand Cherokee Forum 12 06-21-2007 07:45 PM
A/C Probs SCmedic ZJ Grand Cherokee Forum 0 08-28-2006 08:26 AM
a few probs xinnocuous ZJ Grand Cherokee Forum 6 12-21-2004 03:28 PM
ABS PROBS on 98 ZJ njrealtor55 ZJ Grand Cherokee Forum 3 08-10-2004 11:10 PM
