emissions - JeepForum.com
post #1 of 3 Old 03-13-2004, 10:12 AM Thread Starter
greenmachine99
greenmachine99's Avatar
emissions
Took the ZJ in for the 2nd emissions test after failing the 1st time. It failed again after having the whole EGR system replaced. Its running high on hydro carbons. Any idea's what would cause this and how to fix it? Thanks for any info.
greenmachine99 is offline
post #2 of 3 Old 03-13-2004, 10:26 AM
Meerkat
What temperature thermostat do you have? If you are running a 180 instead of the stock 192, the engine will run rich will produce more hydrocarbons.
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
post #3 of 3 Old 03-13-2004, 05:53 PM
shookwell
shookwell's Avatar
ask around, for a few extra bucks you can usually get an emissions sticker even if you cant pass . . .
shookwell is offline
4.7 emissions 05 wk rocks00tj WK Grand Cherokee & XK Commander Forum 0 09-20-2008 03:33 PM
California Emissions ecu and emissions bjl95mustang ZJ Grand Cherokee Forum 0 07-13-2008 02:11 PM
Not passing emissions?? SandroCosta ZJ Grand Cherokee Forum 13 01-16-2007 05:07 PM
Emissions? walter_da_jpr ZJ Grand Cherokee Forum 1 06-03-2005 03:41 PM
emissions greenmachine99 ZJ Grand Cherokee Forum 4 03-26-2004 06:01 PM
