elimitating trak-lok - JeepForum.com
post #1 of 7 Old 08-04-2009, 09:04 AM Thread Starter
dksob81
I have a 98 5.9Limited - DANA44 rear-end w/ trak-lok. well it making a horrible clunking/groaning noise while turning and sometimes after turning while going straight. I would like to eliminate the trak-lok unless someone knows how to get rid of this noise. I have already done a fluid change and added Mopar Friction Modifier and followed the procedure in the FSM of driving in a figure 8 pattern repeatedly to lubrcate everything and it still has this noise.
Any help would be much appreciated.
joe
dksob81 is offline
post #2 of 7 Old 08-04-2009, 10:59 AM
StrokedWJ
StrokedWJ's Avatar
The only way to eliminate the trak-lock would be to swap in a standard (open) carrier. That will require having your ring and pinion professionally set up for proper gear mesh pattern.
2000 WJ 4.5L - Stroked, Locked, & Long-Armed
Looking for 6" WJ springs!
StrokedWJ is offline
post #3 of 7 Old 08-04-2009, 03:37 PM
elmer_fud
how do the spider gears look?
Brian
95 ZJ, 5.2 V8,160,000 miles
Originally Posted by Speedycat View Post
I am not one to be changing lanes at 70 mph on a lifted truck on 33's, but since I am in Miami, I have to be prepared for the continuous influx of new drivers whose previous ride was a bicycle with wooden wheels.
Originally Posted by FPKites View Post
badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, Mushroom!!! :D
Originally Posted by ZeeJay1997 View Post
Or just tie a 12 lb fish to a one foot pipe.
elmer_fud is offline
post #4 of 7 Old 08-04-2009, 07:46 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
get it rebuilt or get an open carrier set up for it. either solution is a minimum of a couple hundred dollars.
ratmonkey is offline
post #5 of 7 Old 08-05-2009, 06:44 AM Thread Starter
dksob81
well if anything i would rebuild it myself. do you think the noise is just worn out clutches?
dksob81 is offline
post #6 of 7 Old 08-05-2009, 08:53 AM
kingvm
kingvm's Avatar
2005 WK
I would lean toward checking the spider and side gears. The traclock should not cause noise when going straight and if it is trashed you probably would have found trash and pieces in the diff when you changed the oil.
05 Grand Cherokee Limited, 5.7 hemi, quadradrive II, Nav, 3" lift, JK Rubi wheels/tires, 4xGuard skids
kingvm is offline
post #7 of 7 Old 08-05-2009, 07:51 PM
vansskaterfreek
had the same issue with my 5.9.... the 2 clutches that are used as a "spring" in the trac loc system on mine blew apart into like 15 peices..... it looked ok when i pulled the cover off, but when i took the clutches out, i saw the damage
1998 ZJ 5.9L 122k miles - DD, 242 swap, 3.5" RE, 32" BFG M/T, safari rack, roof-mounted lights, custom steel front bumper with hitch reciever, 10k winch :)
2004 WJ 4.7L 107k miles - her daily driver, 2" daystar BB with scorpion shocks.. not too bad! stuffed 265/65/17 General Grabber AT2'S
vansskaterfreek is offline
Rear diff oil change, Trak-lok? dromeda WK Grand Cherokee & XK Commander Forum 6 09-17-2009 06:29 PM
Can I put a Vari lock axle on a Quadra-trak 2 system? jschellberg ZJ Grand Cherokee Forum 2 07-14-2009 01:49 PM
How much ATF+4 in Quadra Trak 2? 4jeepers ZJ Grand Cherokee Forum 4 11-09-2008 02:21 PM
Vari-Lok or Trak-Lok---Do I Have it? Greydane WJ Grand Cherokee Forum 5 07-26-2007 09:03 PM
trak lok times ZJ Grand Cherokee Forum 11 10-02-2006 03:54 PM
