Electrical system? - JeepForum.com
post #1 of 2 Old 10-20-2002, 05:19 PM Thread Starter
rpeAMP
Electrical system?
My friend just bought a used Jeep Grand Cherokee (97) and is having some problems with the electrical system. Sometimes when starting up, nothing electrical in the truck turns on. No speedometer, tachometer, A/C, radio, anything. The only thing that is apparent that works is the lights and the odometer. Any ideas here? Battery is good, and as far as I know, alternator is good as well. After we pull a few fuses, it works just fine (until it happens again). I think she also said that her power doors won't work after this happens as well.
Any ideas or suggestions?
BTW- My parents have a Chrysler Town and Country that did this occasionnally, so it must be a Chrysler-specific problem?
Thanks for any replies.
rpeAMP is offline
post #2 of 2 Old 10-20-2002, 11:44 PM
moabster
moabster's Avatar
2011 WK
It sounds like you have a bad connection going to one of the computers. I would first try unplugging the connector the computer and spray the contacts in the plug with contact cleaner. (You should be able to pick some up at radio shack.) Also make sure the ground connections are good (tight and not rusted or corroded.)
You said it would come on after you pulled fuses. You may have a short or an open somewhere around the fuse block as well. Once you get the gauges to work temporarily, have someone wiggle the wires going into the fuse block to see if this affects the gauges.
Intermittent electrical problems are a pain to find. Be patient and don't be too rough on the wires or you could break something new.
Good Luck!
2000 Jeep Grand Cherokee V8 Stock
93 YJ I6 hard top (really belongs to SPEED)
RE 4.5" Extreme Duty Lift, Advanced Adapters SYE, Tom Woods CV Drive Shaft, EA589 10" rims with 33" x 12.5" MT/Rs
Bullet Proof Front and Rear Bumpers and Tow bar
moabster is offline
Service Electrical Brake System light? beeneeb WK Grand Cherokee & XK Commander Forum 14 06-23-2015 02:02 PM
Electrical System is PO'd xa310165 WK Grand Cherokee & XK Commander Forum 11 10-22-2009 03:13 PM
Possible electrical/charging system issue. GCherokee2001 ZJ Grand Cherokee Forum 0 11-08-2007 01:25 PM
Electrical System Problem MWLThe1st ZJ Grand Cherokee Forum 3 01-22-2007 02:19 PM
Electrical system/computer goes haywire SRT99WJ WJ Grand Cherokee Forum 1 05-17-2002 06:48 PM
