Electrical Issue - JeepForum.com
post #1 of 12 Old 09-16-2010, 04:15 PM Thread Starter
chachi77
1993 FSJ Cherokee
Electrical Issue
Hi guys,
I have a 93 Grand Cherokee 5.2 L . It blew the 2 X 60 Amp Alternator fuses under the hood as it left me standed. I have since replaced the fuses and have no power going to the coil. It turns over but no fire. Ive been tracing wires to find a short but am dumbfounded. Any one had this issue before and can steer me in the right direction
chachi77 is offline
post #2 of 12 Old 09-16-2010, 04:37 PM
iPlay1515
Originally Posted by chachi77 View Post
Hi guys,
Check fuses F2 20 amp and F15 30 amp.
iPlay1515 is offline
post #3 of 12 Old 09-16-2010, 04:43 PM Thread Starter
chachi77
1993 FSJ Cherokee
Power coming to all fuses and fuses test ok.
chachi77 is offline
post #4 of 12 Old 09-16-2010, 04:53 PM
iPlay1515
F2 supplies power to the automatic shutdown relay which in turn applies power to the coil.
The PCM provides ground to the coil similar to old style mechanical points.
Check the bottom side of the auto shutdown relay for numbers and post on forum thread.
post #5 of 12 Old 09-16-2010, 04:57 PM Thread Starter
chachi77
1993 FSJ Cherokee
The auto shut down relay tests for power....even switched out the relay ....still not getting power to coil
chachi77 is offline
post #6 of 12 Old 09-16-2010, 05:05 PM
iPlay1515
The FSM shows an 18awg Dark Green / Black wire from the ASD Relay to a two wire connector at the coil.
post #7 of 12 Old 09-16-2010, 05:06 PM Thread Starter
chachi77
1993 FSJ Cherokee
the shutdown relay # 56006707 83159 2402 is also the same relay # for the AC relay and fog lamp relay.....and all have power coming to them and I tried switching them all around as well
chachi77 is offline
post #8 of 12 Old 09-18-2010, 05:49 AM
mca1977jpsnet
So you have no spark?? Do you have no fuel either? Check crank sensor and cam sensor/magn pickup (in dist) for power in/output.
mca1977jpsnet is offline
post #9 of 12 Old 09-18-2010, 08:31 AM
iPlay1515
If the coil does not have 12 volt power when the ignition is on, nothing else matters right now.
We have room but for one flag, the American flag . . . We have room but for one language, and that is the English language . . . And we have room for but one sole loyalty...and that is a loyalty to the American people. T. Roosevelt 1919
post #10 of 12 Old 09-19-2010, 03:10 PM Thread Starter
chachi77
1993 FSJ Cherokee
Figured it out guys...My buddy came over with a scanner and pulled code #11 crank signal ....its the crank position sensor....why it blew the fuses he has no idea....Ill try to swap it out by next weekend. Wish me luck!! ha ha
chachi77 is offline
post #11 of 12 Old 09-22-2010, 07:09 AM
mca1977jpsnet
When you replace crank sensor check fuse, connector, and wiring for damage or corrosion.
post #12 of 12 Old 09-23-2010, 12:03 PM Thread Starter
chachi77
1993 FSJ Cherokee
The crank sensor had actually broke off form its housing causing it to drop a bit blowing 2X60 AMP fuses for the alternator. Replaced the fuses and crank sensor, fired up perfectly. All is well in Jeep town. Now shes up for sale!!!
chachi77 is offline
AC Electrical Issue SylvesterCat ZJ Grand Cherokee Forum 1 08-05-2010 10:23 AM
electrical issue please help Scibbyz99WJ ZJ Grand Cherokee Forum 3 06-06-2010 09:22 PM
Electrical issue, again! newberrykc ZJ Grand Cherokee Forum 12 03-08-2010 05:41 AM
'93 Electrical Issue alec_b ZJ Grand Cherokee Forum 1 03-24-2009 04:55 PM
Electrical Issue jdminton ZJ Grand Cherokee Forum 13 03-21-2008 11:24 AM
