post #1 of Old 01-28-2010, 08:43 AM Thread Starter
pcv57
Electrical gremlins
I'm hoping someone may have some ideas as to what's going on with my 97 Grand Cherokee V8. About a month ago, after shutting off the engine the car would not restart. There was no power to anything electrical but my phone charger light would go on and off continuously. After a some time, the car would restart. Then one day the car just died while driving it and couldn't even take a jump start.
Mechanic installed a new battery and alternator which seemed to do the trick for awhile. While driving the other day I noticed the battery gauge peg all the way to the right meaning the battery was being overcharged. I stopped, opened the hood to check things out and then the car wouldn't start again and I noticed the phone charge light going on and off again. It did start some time later.
I would appreciate any ideas as to what could be going on. My mechanic is at a loss.
thanks
pcv57 is offline
post #2 of Old 01-28-2010, 11:20 AM
greasefingers
greasefingers's Avatar
1994 ZJ
I am not sure what the issue is, but I would definitely start with the PDC (power dist ctr) The thingy behind the battery. I would closely examine the wiring harness entering it. I would also push and pull on the wires while some is cranking the engine.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #3 of Old 01-28-2010, 11:29 AM Thread Starter
pcv57
Hey Steve,
Thanks for the reply. I have to start somewhere so that sounds good to me. I'll check it out and see if there is a loose connection or bad wire.
Paul
pcv57 is offline
electrical gremlins JackStraw ZJ Grand Cherokee Forum 2 09-30-2009 08:43 PM
Electrical gremlins TPS/IAC Chloetar ZJ Grand Cherokee Forum 3 05-24-2007 08:40 PM
electrical gremlins crexor ZJ Grand Cherokee Forum 0 01-21-2007 02:15 PM
Electrical gremlins Beachy ZJ Grand Cherokee Forum 6 09-10-2006 10:06 PM
Electrical gremlins buzzbomb ZJ Grand Cherokee Forum 9 12-26-2002 12:14 PM
You may not post new threads
You may not post replies
